Tractor Talk Discussion Forum
TA Eliminator on 806
BB
10-20-2003 07:25:27
I am in the last steps in putting the speed transmission together after installing a TA eliminator kit. The only part that has me confused is the new gear in the kit. The instructions seem to want to install it on the countershaft, being driven by the origional constant mesh (direct drive) gear reinstalled on the new shaft from the kit. If I have this right then the old gear drives the new one instead of the origional. Isn't mixing new & old gears a no no ?? If anyone has done this before I would appreciate your input.
Thanks.
RJ-Az
10-20-2003 17:23:18
 Re: TA Eliminator on 806 in reply to BB, 10-20-2003 07:25:27
This ain't a rocket ship! Unless the old gear is noticibly worn there should be no problem there. I did one 3 years ago and it worked just fine. If you are uncomfortable mixing old and new just go ahead and price the replacement gear. Those 806 bull gears were so noisy I bet you cant tell the difference.
B B
10-21-2003 03:53:30
 Re: Re: TA Eliminator on 806 in reply to RJ-Az, 10-20-2003 17:23:18
Thanks for the reply. I just get suspisious when things seem so simple. Old age I guess !
