Tractor Talk Discussion Forum
JD Tractor help. (Please!!)
Jeff
10-20-2003 10:27:10
I am trying to figure out what kind of JD tractor I recently obtained. Any help or info. would be appreciated. The only number on the engine that I could find was 23E195-88 (or 23E195488). The tractor type: T213R and serial number 188145R.
AJ
10-20-2003 14:59:02
 Re: JD Tractor help. (Please!!) in reply to Jeff , 10-20-2003 10:27:10
Jeff. You have a 4020. This is the break down of T213R188145:
T - Tractor
2 - 4020
1 - Chassis Type (1=Row Crop)
3 - Fuel Type (3=diesel)
R - Manufacturing Facility (R=Waterloo, Iowa)
188145 is the serial number. This one was manufactured in February of 1968.
TJ
jeff
10-20-2003 16:32:57
 Re: Re: JD Tractor help. (Please!!) in reply to AJ, 10-20-2003 14:59:02
Thanks TJ!!! Any idea on the value? Motor and hydrolics recently rebuilt. Turn Key. New seat, fresh paint. I also have an auger for the tractor. serial #TY0031A023241
THANKS AGAIN,
twopop
10-20-2003 19:06:24
 Re: Re: Re: JD Tractor help. (Please!!) in reply to jeff, 10-20-2003 16:32:57
somewhere between $8 to 10,000.00
jeff
10-20-2003 20:02:25
 Re: Re: Re: Re: JD Tractor help. (Please!!) in reply to twopop, 10-20-2003 19:06:24
Sorry to bother but I have another question for you. I don't have a title for the tractor. Does the gov. monitor or license farm equipment?
twopop
10-20-2003 20:42:59
 Re: Re: Re: Re: Re: JD Tractor help. (Please!!) in reply to jeff, 10-20-2003 20:02:25
last i knew of in calif.there,s no title required
jeff
10-20-2003 19:57:31
Thanks twopop! Any suggestions on where to advertise the sale? I'm actually in Southern California where farming is limited.
twopop
10-20-2003 20:40:56
 Re: Re: Re: Re: Re: JD Tractor help. (Please!!) in reply to jeff, 10-20-2003 19:57:31
where abouts in so.cal. I am in new mexico now but was raised in chino.advertise it in riverside,san bernardino.chino area. alot of dairies.advertise in fastline mag.
Jeff
10-21-2003 09:18:12
 Re: Re: Re: Re: Re: Re: JD Tractor help. (Please!! in reply to twopop, 10-20-2003 20:40:56
I'm in Orange County but the tractor is up in the Twentynine Palms area. Good points on the area's!! I didn't think of the dairies! And I will check out fastline mag. Do you think it's worth putting an add on this web site?
Thanks!!
twopop
10-21-2003 16:20:02
 Re: Re: Re: Re: Re: Re: Re: JD Tractor help. (Plea in reply to Jeff, 10-21-2003 09:18:12
it certainly wouldnt hurt putting it on the yt ad page,hey,it doesnt cost.your serial # shows it to be a 4020 not a 4520.4520s arent worth as much as a 4020
Jeff
10-22-2003 11:32:45
 Re: Re: Re: Re: Re: Re: Re: Re: JD Tractor help. ( in reply to twopop, 10-21-2003 16:20:02
Thanks for all of your help!!
greenbeanman
10-20-2003 11:38:19
Jeff, I have a Hot Line book of farm equipment, but it would be better if you would narrow the field somewhat.
What age of tractor, You can get some idea from the sheet metal styling. The "88" in the number may indicate that.
What category size of tractor. Compact, utility, mid size, or 100hp or greater.
How many cylinders? What fuel?
After narrowing the field some, I might be able to find in for you. Expect someone will know right off however.
Jeff Stephens
10-20-2003 13:41:51
 Re: Re: JD Tractor help. (Please!!) in reply to greenbeanman, 10-20-2003 11:38:19
Thanks for the reply. From looking through similar JD's for sale on this web page. It looks like a 4520 (I believe was the model No.)
I was told it was 68', however again from looking at pics, it could be up to a 72' Being completely illiterate to tractors. The rear tires are 5'-6' tall. It has a 6 cyl. diesel engine. Exhaust and air cleaner are out of the front hood. Hydrolic levers are at the dash and the throttle rpm adj. is on the stear column. I believe it has 2-3 reverse gears and 5-6 forward gears. It has double lights on each side located just undert the rear fenders.
Thanks for your help.
JMS/MN
10-21-2003 01:00:42
 Re: Re: Re: JD Tractor help. (Please!!) in reply to Jeff Stephens, 10-20-2003 13:41:51
Serial number should positively ID the tractor. Hydraulic levers on the dash would indicate the older style- Didn't the hydraulic SIDE console start in late 68, or 69? POWERSHIFT tranny had 8 forward, 4 reverse. Synchro had two or three reverse and eight forward speeds, had to be clutched to shift. 4520 styling was similar, but the serial number would ID the tractor. Previous poster had the breakdown as to what letters and digits mean.
JMS/MN
10-21-2003 01:00:14
Serial number should positively ID the tractor. Hydraulic levers on the dash would indicate the older style- Didn't the hydraulic SIDE console start in late 68, or 69? POWERSHIFT tranny had 8 forward, 4 reverse. Synchro had two or three reverse and eight forward speeds, had to be clutched to shift. 4520 styling was similar, but the serial number would ID the tractor. Previous poster had the brakdown as to what letters and digits mean.
