Tractor Talk Discussion Forum
Converting from Magneto to Elect. Ig. Dist. 52 Cas
Dennis T
10-20-2003 15:45:01
Looked in Pertroniz.com and can't find cross to my make and model or even anything that is close. Is there something I'm missing?
Dennis
10-21-2003 07:41:37
 Re: Converting from Magneto to Elect. Ig. Dist. 52 in reply to Dennis T, 10-20-2003 15:45:01
Just checked the cap on my magneto for continuity between the middle pole inside and the outside pole to the coil, completely open. I think all I need is a new cap. Anyone know a source?
RAB
10-21-2003 09:38:11
 Re: Re: Converting from Magneto to Elect. Ig. Dist in reply to Dennis, 10-21-2003 07:41:37
Are they directly behind one another? I would have thought there was a way to reconnect them.
Regards,RAB
Dennis
10-21-2003 15:06:51
 Re: Re: Re: Converting from Magneto to Elect. Ig. in reply to RAB, 10-21-2003 09:38:11
cleaned the contact and it works
bill
10-20-2003 17:58:08
are you going from mag to dist on a case tractor and what model? I have done this on D-C and others However I must say getting the mag rebuilt properly gives a more dependable machine for most accplations
Dennis
10-21-2003 06:40:27
 Re: Re: Converting from Magneto to Elect. Ig. Dist in reply to bill, 10-20-2003 17:58:08
Yes, Mag to dist. on 52 Case SC
TO35
10-20-2003 17:51:22
Dennis...give them a call with your dist. type and they should be able to fix you up. They have lots of their systems that will fit appiications not list in the online catalog....
best wishes
TO
Dennis
10-21-2003 06:42:01
 Re: Re: Converting from Magneto to Elect. Ig. Dist in reply to TO35, 10-20-2003 17:51:22
I called but they couldnt match my Magneto up with a dist.
