Tractor Talk Discussion Forum
Caterpiller D8 weight
Stacy Aghedo
10-20-2003 15:50:32
Please, please could anyone tell me how many tons a Caterpiller D8 weighs, as am shipping one and need to know it's weight.
Thanks
Larry
10-21-2003 06:38:35
 Re: Caterpiller D8 weight in reply to Stacy Aghedo, 10-20-2003 15:50:32
starting in 1935, prefix 1h or 2u were all about 34000 lbs to just under 36000 lbs. The H models,
1958 jumped to 48000+. The K models were just over 57000 lbs. These weights include a 170 lb operator, and all fluids. They do not include ANY attachments. If your moving an H model,with a semi-U blade, I always use 60,000lbs. Larry
MarkB
10-20-2003 19:44:49
If I recall correctly, a D8 model 14A with a bulldozer and cable control unit attached weighs around 60,000 lbs.
If your shipper doesn't have a good idea what your machine weighs, maybe you should find another trucker. You need someone who specializes in moving heavy equipment.
JIM HOBBS
10-20-2003 17:12:07
if its an original d8 then your only looking at 25 tons for blade and all, because a d8h with blade weighs 70000lbs.
what is the serial number and i could tell you exactly??
jim
JOHN (LA)
10-20-2003 16:59:55
Hard to say with info provided! Does it have a blade and ripper installed? What type? These items can change weight by 10,000 to 12,000 lbs each. What model is it. I think you would be better served by a quick call to CAT with your model number and what attachments it has installed and let them tell you the weight. As a guess and only a guess I would say 80,000 to 90,000 lbs or 40 to 45 tons. If you are going more than a short distance you should be able to get it down to say 30 to 35 tons for shipping by stripping and loading items onto a second truck. Will save you on your over weight permit and DOT will probley insist on it anyway.
AGAIN this is only a guess!!!
