Tractor Talk Discussion Forum
MF135 knocking
James
10-23-2003 17:46:29
Have a MF135 3 cyl gas perkins. With 3 point up or down and tractor running in or out of gear and clutch out I sometimes hear a knocking around trans/gear shifts. When I push clutch all the way down it stops. Any ideas?
Willy-N
10-24-2003 08:25:19
 Re: MF135 knocking in reply to James, 10-23-2003 17:46:29
I have the same Tractor and the pump will knock when I am lifting around 1,800 lbs on my rear Fork Lift attachment hooked to the 3-Point. Never knocks any other time tho. Mark H.
david val
10-24-2003 01:34:50
one of the hitch levers (i don't remember which) is in 'contant pumping' (stamped on the quadrant).
david
James Wyatt
10-27-2003 17:31:50
 Re: Re: MF135 knocking in reply to david val, 10-24-2003 01:34:50
David val, I did have the hydraulic lever all the way up in constant pumping, when i brought it down to transport it stopped. thanks
marlowe
10-23-2003 18:28:46
hyd. pump in the rear end
R. Marg
10-23-2003 17:50:29
sounds like a loose bearing some where in that area this is just a guess but it sounds like that could be the problem or you have something loose in side
