Tractor Talk Discussion Forum
Steering problem on JD - B
Kenny
10-26-2003 15:25:27
I have a 1938 unstyled B and the bearing on the steering shaft was bad and it has about 3/4 of a round of play in the steering wheel. I have replaced the bearing but still have the play in the steering wheel. What do I need to do to get the play out. THANKS
Gary-Miss
10-27-2003 18:03:37
 Re: Steering problem on JD - B in reply to Kenny, 10-26-2003 15:25:27
Haven't worked on one quite that old that I can recall. On the later models, you remove the top cover, then feel around the vertical shaft gear for a large screw, remove it and rotate an eccentric which moves the vertical shaft gear closer to the worm. You then replace the screw.Possibly yours is similar. Good luck.
