Tractor Talk Discussion Forum
Case 450 loader question - need help
M.D.
10-27-2003 14:55:48
Having trouble getting my loader started. After cranking it some it has melted the battery clamp on the ground post on the battery. Sure would appreciate some advice. It turns, but not fast enough to fire.
R. Marg
10-27-2003 15:35:00
 Re: Case 450 loader question - need help in reply to M.D., 10-27-2003 14:55:48
sounds like the starter needs some TLC or in other words replaced or rebuilt hope this helps
Jerry l /az
10-27-2003 15:44:32
 Re: Re: Case 450 loader question - need help in reply to R. Marg, 10-27-2003 15:35:00
Trace the cable from the starter to batt, May have a break in the insulation, (rubbing on the frame or other chassie part causing a short) hope this helps..... ..Jer
