Tractor Talk Discussion Forum
Oil
junkandjunk
10-30-2003 14:25:20
What oil should I use in my Grandpa's old 1947 Blizburg?
Frank M.
10-31-2003 18:08:42
 Re: Oil in reply to junkandjunk, 10-30-2003 14:25:20
I didn't know the Blitzburg needed oil. My great grandfather always used 90 proof whiskey. ( at least that's what he told my great grandmother) Must have used a lot too. He always carried a jug on the tractor with him. Had to refill the jug every day.
Fredwi
10-31-2003 07:09:57
Why don't you just use the Blizburg oil? You can
buy it anywhere and its cheap when buying by the
100 gallon barrels. (otherwise just let grandpa
do it.)
Ben in KY
10-31-2003 08:09:18
 Re: Re: Oil in reply to Fredwi, 10-31-2003 07:09:57
Absolutely, Only use Blitzburg oil. Especially only use Blitz-tran in the transmission and hydraulics.
DRL
10-31-2003 06:59:51
I've heard that those old Blizburgs do real well on bacon grease!
dirthog
10-31-2003 12:12:18
 Re: Re: Oil in reply to DRL, 10-31-2003 06:59:51
I've never tryed bacon grease but I've been using discarded deep fryer grease in my 39 blitz since 37 with no problems whats so ever.
deadeye
10-31-2003 06:10:29
Put in what you have that is 30W that is the cheapest. You are not going to wear it out in your lifetime. The only way you will is if you don't put any oil at all in.----deadeye
sammy the RED
10-30-2003 22:29:56
Use the slippery kind.
Les...fortunate
10-30-2003 18:47:46
Who says 1947 is old?????
Alberta Mike
10-30-2003 18:04:15
Can't help you with the oil, but what the heck is a Blitzburg?
buickanddeere
11-01-2003 16:45:17
 Re: Re: Oil in reply to Alberta Mike, 10-30-2003 18:04:15
Blizburg is a bit of a running joke. Usually refers to some modest device and the exagirated descrition of it's abilities. A few threads back I was is a crusty mood and asked why someone was asking for the 40th time this year," is it alright to run unleaded in my xxx". The other favourite repeat question is of course the straight weight/multiweight and detergent/non detergent oil. Many people seem to believe that the new oil wrecks the old engines. Fact is the tractor/truck/what ever was parked 30-50 years ago because the engine was rattling to death then.
DRL
11-01-2003 20:10:37
 Re: Re: Re: Oil in reply to buickanddeere, 11-01-2003 16:45:17
Soooo, are you saying it's OK to run unleaded fuel in Grandpa's Blizburg without any additives???
buickanddeere
11-01-2003 23:01:03
 Re: Re: Re: Re: Oil in reply to DRL, 11-01-2003 20:10:37
A little top oil from the barber shops of the late 40's, also used to style hair is best.
DRL
11-02-2003 14:35:19
 Re: Re: Re: Re: Re: Oil in reply to buickanddeere , 11-01-2003 23:01:03
How much per tank. Seems like a little dab will do ya.
