Tractor Talk Discussion Forum
snowblower gas leak
farmallmaniac
11-03-2003 13:54:31
i attemted to fill my snowblower up with gas to find i have a gas leak under my muffler. there looks to be a hose disconnected but i can't find the fitting that it connects too. the hose seems to lead back to tge primce because when i push the primer air comes out of the house. thanks for all help
Ryan
Rauville
11-04-2003 04:25:03
 Re: snowblower gas leak in reply to farmallmaniac, 11-03-2003 13:54:31
About every 3 years on my snowblower, I have to redo the primer line connection at the carb. because of softening of the rubber hose due to using ethanol gasoline. The primer fitting is just a short nipple that the hose slides on. I've had my snowblower for 23 years, and this seems to be the only negative effect of ethanol.
JDK
11-03-2003 14:19:44
If hose puffs air from primer it should hook to nipple on carb/or carb manifold.What brand engine?
farmallmaniac
11-03-2003 14:44:04
 Re: Re: snowblower gas leak in reply to JDK, 11-03-2003 14:19:44
its a snapper. when i looked closer i saw 2 screws on springs one you can push and gas comes out the other doesn't move.
sry misspelled
11-03-2003 13:56:23
"tge" is "the" and " primce" is "primer" sry bout that
