Tractor Talk Discussion Forum
IH 560- oil out breather pipe
Mark T.
11-03-2003 17:47:51
Recently I noticed that I am getting what looks like oil out of the breather pipe on my IH 560. The volume is greater when it first start up but continues. Thr tractor sits quite a bit, it runs probably one weekend per month. Any ideas?
Larry
11-04-2003 08:25:01
 Re: IH 560- oil out breather pipe in reply to Mark T., 11-03-2003 17:47:51
I agree with Jim and old, start by using some good engine cleaner, I like rizalone, to free any sticking rings. The way you describe your usage of the tractor, sticky rings could be the problem. Especially if when you run it, it dosen't run for a long time. I'd also do a leak down test on the cylinders and try to determine where the blowby is coming from. Good luck Larry
Chris-se-ILL
11-04-2003 08:19:30
Both my Farmall 560's have an oil-bath style air cleaner (air is drawn through an oil bath at the bottom of the intake tube). The only thing I can think of (off the top of my head) could possibly be a couple of burned intake valves allowing combustion gases to be blown into the intake pipe and forcing some oil back up the intake pipe.... just a guess though!
Jim J
11-03-2003 21:24:51
Is your tractor a gas or a diesel?
Mark T.
11-04-2003 10:08:36
 Re: Re: IH 560- oil out breather pipe in reply to Jim J, 11-03-2003 21:24:51
It's gas
old
11-03-2003 18:16:08
Sounds like blow by which is either your rings are getting bad or sticking or your valves /seals are getting bad I'd try some marveal mystrey oil sorry about the spelling I'd put some in the fuel and the oil hope this helps you some
I can read
11-03-2003 21:41:08
 Re: Re: IH 560- oil out breather pipe in reply to old, 11-03-2003 18:16:08
Don't worry about your spelling Ollie, I can read your hand writeing.
old
11-03-2003 22:07:59
 Re: Re: Re: IH 560- oil out breather pipe in reply to I can read, 11-03-2003 21:41:08
the names OLD not ollie thank you
Is that you
11-04-2003 20:53:16
 Re: Re: Re: Re: IH 560- oil out breather pipe in reply to old, 11-03-2003 22:07:59
Marg
