Tractor Talk Discussion Forum
O/T for you science buffs
Jonathan
11-07-2003 08:40:49
I had a physical science teacher in high school that told me if I was to point a gun straight up in the air and fire it, the bullet would go up, and then fall back to the ground, reaching the same speed as when it left the barrel. Is this fact or fiction?.
IT CAN BE DONE
11-09-2003 10:17:16
 Re: O/T for you science buffs in reply to Jonathan, 11-07-2003 08:40:49
The round can land at a speed equal to its muzzle velocity - and in real earth conditions. The trick is to use a different sort of gun, with a very slippery round, and get most of the return acceleration done before you hit dense atmosphere - and build the gun the same way you'd build a good tractor engine.
A little background first: In posts below, I've run ballistics formulas and 32 ft./sec./sec. formulas in a spreadsheet and found the normal ballistics you get from www.remington.com give you 2500 to 3500 fps out of the muzzle with 2500 to 4000 ft. lbs. of "torque" on a 40 to 200 grain round that has .21 to .50 drag coefficient from a 24" barrel. It goes up a mile or two, gets to 0mph and falls at 32 ft./sec/sec. Usually the result is 200 to 300 fps when it hits. If you make goofy assumptions like no atmosphere but still 1G earth gravity and set drag coefficent to 0, you can get bullets flying up 20 or 30 miles - but they still land 100 or 200 fps short of 0 atmosphere muzzle velocity speed. If you go to the moon, they fly real well at .2G moon gravity, but you're bit on the backside as .2G = .2*32ft/sec/sec. You need more distance going up, or in other words, a more powerful gun. Then I remembered something I'd read about Gerald Bull and super guns, and realized it can be, and actually has been done. The method even has something to do with old tractors.
Think of the bullet as a tractor piston, and the gun barrel as a tractor cylinder. The tractor has piston rings, but they're missing in the gun. Bull figured out a few things, one of them was adding piston rings to the gun. He took a device that sealed to the barrel and placed a round about 80% the size of the bore inside it. The device is formed in two parts, so it falls away after the round has left the muzzle, while the light sub caliber round keeps going. Guys who hunt with .50 cal black powder can find basically the same thing in their sabot rounds. Next trick was that with those "piston rings", the bullet doesn't need to be shaped to seal to the barrel. Heck with boattail rounds, he shaped his bullet to look something like a football. Instead of the .2 to .5 aerodynamic drag you're used to seeing in ballistics charts (or cars and trucks) this thing has a coefficient approaching .1. In other words it slips throught he air with the greatest of ease. Last trick was increasing torque. A longer stroke engine increases torque, right? Same trick with a long barrel gun. The same .44 caliber round has more punch when fired from a Remington rifle than it does from a Colt pistol. Reason is that you use more of the explosion energy to push the round, and less of it escapes at the muzzle.
Enter Uncle Sam who's looking for a cheap way to get extra supplies up to astronauts. They hire Bull to design a super gun which would go up 100 miles then fire a small rocket to reach low orbit. They take two 16 inch naval guns, weld them together, and get a barrel about 100 feet long. Ship it to Arizona, and point it straight up. Insert the football shaped round they call a Martlett inside the piston rings or sabot, and pull the trigger. In Nov. 1966, they got a 185 lb Martlett to an altitude of 111 miles. It falls at least 90 miles at 32 ft/sec/sec before it encounters much atmosphere - and ends up hitting faster than when it left the barrel.
Don't try this at home, as you're likely to end up demolishing your house. And don't be Gerald Bull, as he got assassinated for hiring out to a guy named Hussein. The point is something most tractor guys already suspect; you can do most anything with a bit more power.
Rod F.
11-09-2003 17:10:12
 Re: Re: O/T for you science buffs in reply to IT CAN BE DONE, 11-09-2003 10:17:16
Well, well. This has been an interesting discussion. You put a lot of time into this one. I won't argue the numbers you put up, but still wonder about some of it. But since you asked about flaws in your theory below, I'll take a shot, so to speak. First, I don't see why muzzle velocity is important, and I am confused about "torque". So, as I think of this in purely theoretical terms, and for a moment, I will ignore all forces at work except gravity. We have a bullet in the gun, we point it straight up, and fire. Now, the force of the explosion and expansion force the bullet away, it increases in velocity, and should reach Vmax as it clears the barrel. Correct? Now, this is where I do not see what role torque plays. That to me seems to be a linear force. Also, at this point I assume that the bullet becomes a simple projectile or glider, as it no longer receives any energy from the explosion. We also know that gravity alone will exert force in a manner that will cause an acceleration of 32 feet/sec. So, that in theory should also cause a deceleration of 32 feet/sec. So, the bullet will rise in the vertical plane, decelerating at a rate of 32 feet/sec as gravity slows it down, stops in mid air, and then begins to fall, now accelerating at a rate of 32 feet/sec reaching Vmax at the point of begining, assuming that to be the end of the barrel. Vmax should be the same when the bullet returns as when it left. So, the way I see it, purely in a theoretical sense, is that Vmax is not a relevant number, whether it is 100 feet/second or 1000 feet/second. This being true, the size of the charge would affect Vmax, which would determine the distance traveled, but the bullet would have the same velocity at any given point in it's travel, without reguard for it's direction of travel. And I truly don't understand where torque figures into this. Not trying to flame you here, just curious.
Rod
Steve - IN
11-09-2003 20:11:46
 Re: Re: Re: O/T for you science buffs in reply to Rod F., 11-09-2003 17:10:12
Rod F.
The original question was:
"if I was to point a gun straight up in the air and fire it, the bullet would go up, and then fall back to the ground, reaching the same speed as when it left the barrel. Is this fact or fiction?."
That's why the muzzle velocity, or the speed it was traveling when it left the barrel is important. Gotta answer the question - so you have to know the original velocity to compare it to the final velocity when it hits the dirt.
A ballistics table rates the speed, force, and air friction coefficient for a particular round. The force, energy, punch, of the round is rated in foot/pounds. Torque is rated in foot pounds. As one of the themes was to draw some relation to a tractor engine -- seemed a bit interesting to throw in "torque" in a tongue in cheek sort of way instead of using the words force, energy, punch, etc. over and over ad nauseam. Yes, torque is properly a turning force - but it's easily translated to lifting force as the common currency is foot/pounds.
The energy number in foot pounds already assumes a 1G gravity by telling you a 2000 ft/lb round can lift 1 pound 2000 feet, half pound 4000 feet, quarter pound 8000 feet, and so on - all ratings done on earth - and with a given amount of powder charge in the round. So the gravity correction is basiclly "built-in" with differences that are negligible. The wind resistance or drag coefficient get substantial with various shapes of bullets, though.
Think that covers all your questions, yes?
Jonathan....Thanks everyo
11-10-2003 07:19:19
 Re: Re: Re: Re: O/T for you science buffs in reply to Steve - IN, 11-09-2003 20:11:46
I guess....It's so confusing to real all of the responses. I'm understanding it would be impossible for the bullet to reach muzzle velosity because of drag on the way down. I'd also like to thank everyone who responded to this and I can't believe how many posts, this has to be about the longest thread I have seen on here!.
Rod F.
11-10-2003 06:47:20
Yep, that about answers the questions. The question I worded was somewhat different from the original. So yes, in reality I do understand why velocity is important. In theory though, I don't follow. Mind, I did assume the only force acting on the bullet to be gravity. So if that were true, then it should decelerate at the same rate as it accelerates. I may well be wrong in that assumption though. I guess I'll have to get the old books out. Been an interesting discussion though. Take care.
Rod
Deas Plant.
11-08-2003 19:06:05
Hi, Folks. As I understand it, terminal velocity for most objects -- except pages of paper, feathers, etc. -- is around 120 mph. I have this faint suspicion that if even something as light as a penny hits you at 120 mph, you ARE going to know about it.
As for the bullet attaining muzzle velocity, let's assume a muzzle velocity of 1,500 fps, x 60(seconds), x 60(minutes), divided by 5280(feet per mile) = 1,022.72 mph. (That distance is not going to be attained because of air resistance.)
I VERY seriously doubt that ANYTHING falling from ANY height within the Earth's atmosphere is going to attain that sort of speed. If my calcs are correct -- and I'm NO maths genius -- terminal velocity, 120 mph, translates to 176 fps, just a little short of the above assumed 1,500 fps muzzle velocity.
Anybody got any corrections here? I'm always open to learning.
You have a wonderful day. Best wishes. Deas Plant.
Nolan
11-08-2003 15:13:25
Fact if it were a frictionless environment. Fiction in the real world because of air friction. It will reach terminal velocity and fall no faster.
As an entertaining sidebar, this claim of bullets falling at muzzle velocity is used by gun control groups who insist thousands of people die every year from falling bullets.
The reality is the bullets reach a terminal velocity that is about the same as a rain drops or a hail stones. People don't die from falling bullets.
Cosmo
11-08-2003 12:45:09
Good grief! Ain't we a long winded bunch? :)
bill b va
11-08-2003 06:20:03
which would you rather have to carry a hundred pounds of lead or a hundred pounds of feathers ?
RAB
11-08-2003 09:02:32
 Re: Re: O/T for you science buffs in reply to bill b va , 11-08-2003 06:20:03
At my age - neither, but if I had to, it would depend on how they were packed and obviously not on the mass!!!
Regards, RAB
Scott Green
11-08-2003 04:05:52
I'm not a scientist , but I can give you reallity. Lets take the feather and bowling ball thery mentioned below. Hold the bowling ball above one foot , and the feather above the other foot. Let go of them both at the same time. It won't take too long to figure out which one falls faster. That's the problem with a lot of this thery stuff. It's not reallity. Take for example , the weather. It is "0" degrees out. If the wind is blowing hard , the weather man may say , it feels like 20 below. He also says it's not 20 below , it's only "0". Lets give the weather man a reallity check. We'll stand him outside at "0". Then , with the same cloths on , we'll turn the wind up to the point where it is 20 below. Reallity is , the weather man turns to ice. Yes , I know , the wind takes the heat away faster. Point is , we all live in reallity. And yes , this goes much deeper.
Larry
11-07-2003 21:33:51
You boys sure have a lot of time on your hands!
LOL Larry
Willy-N Easy test!
11-07-2003 21:18:27
Take a rifle next to a Lake and shoot it straight up into the air on a little off angle and watch for the splash when it hits. Then take the same rifle and shoot into the water little less than a 90 deg angle and see what happens!! I know what happens when you shoot at water close by and what happens is a big hole forms in the water along with a big splash and it looks pretty neat. In fact take a 20 round magizine of .223 or .308 and empty it into a lake for effect once, lot more fun than into the dirt. Just be sure you know where the bullet will go if you do it on a slite angle they can skip for a long ways! Mark H.
well
11-07-2003 20:33:22
I don't know if it's 100% true or not, but there are alot of people confused here.
Things accelerate as they fall, until they reach their maximum speed limited by air friction.
If you drop a penny off of the empire state building, it can kill a person on the ground.
MarkB
11-07-2003 19:21:47
This is true in a vacuum. Not true on earth.
john
11-07-2003 19:40:59
 Re: Re: O/T for you science buffs in reply to MarkB, 11-07-2003 19:21:47
How is this?????
In a vaccum it would never stop going forward!!!
MarkB
11-08-2003 05:17:37
 Re: Re: Re: O/T for you science buffs in reply to john, 11-07-2003 19:40:59
A vacuum has nothing to do with gravity. Let's say you were on the moon, which has no atmosphere. Assuming your bullet doesn't exceed the escape velocity of the moon (a very real possibility), it will decelerate until it stops and returns to the surface of the moon. When it impacts the moon's surface, it will be traveling at the same velocity as when it left the gun.
What happens when you fire a projectile upwards is that the kinetic energy of the projectile is converted into potential energy. When there's no more kinetic energy left, the projectile stops, then falls to earth. As it falls, the potential energy is converted back to kinetic energy. In a vacuum, you 100 percent of the energy you started out with. On earth, a huge amount of energy is lost to air resistance, so the projectile will fall to earth much slower than its original velocity.
jake
11-08-2003 16:47:43
 Re: Re: Re: Re: O/T for you science buffs in reply to MarkB, 11-08-2003 05:17:37
I now know why I missed that deer last year the damn thing jumped into a vacume an the bullet went over its head.
MK
11-07-2003 18:09:21
Fact: when I'm spreading manure and a stone happens to be tucked in the load and rockets upward after hitting the beater, two things are sure. 1) murphy's law is that it's comin' down on me and 2) I'm sure(positive) the rock comes down faster than when the beater propelled it up!!
Steve - IN
11-07-2003 18:18:31
 Re: Re: O/T for you science buffs in reply to MK, 11-07-2003 18:09:21
If the Murphy logic and the down faster than up logic are right -- then all airplanes within a few states will come crashing down on your head within the next 30 minutes!
Duck!
Nebraska Cowman
11-07-2003 17:06:34
just cuz a person is a science teacher does not mean they know everything. It just means they wern't able to make a living doing anything else. A saying my dad always had, "Those that can, Do; those that can't, Teach"
rhud
11-08-2003 00:11:56
 Re: Re: O/T for you science buffs in reply to Nebraska Cowman, 11-07-2003 17:06:34
yeah, i agree with you, thats one problem in the United States educational system. many times the better minds are not doing the educating. one reason our students science scores rank fourteenth with other countries. but its probably asking too much to expect that any one teacher knows everything about everything.
thurlow
11-07-2003 19:54:58
AND; those that can't teach; Preach
Jim.UT
11-07-2003 20:53:03
 Re: Re: Re: O/T for you science buffs in reply to thurlow, 11-07-2003 19:54:58
The way I always heard it was "Those that can't do, teach. Those that can't teach, teach P.E."
JOHN (LA)
11-07-2003 17:25:45
LOL!!!!! !!!!!
JOHN (LA)
11-07-2003 16:56:33
I am no science teacher but I thought every thing fell to earth at the exact same speed no matter what it weighs. The only differance would be from wind shear such as a open piece of paper verses a ball of paper.
Now as for the bullet it would fall to earth at the same speed as anything else. Going up speed would depend on the amount of charge pushing it. A 30-30 would go up slower than a 30-06 but would fall at the same speed as each other.
So I say Fiction!!!!! !!!
rhudson, negating air fri
11-07-2003 16:12:22
it is a fact, except the statement must include the little detail about all this happening in a vacuum. by the same principles a feather and a bowling ball when dropped from the same height would hit the ground at the same time, but again the experiment must be preformed in a pure vacuum. if there is no air, there is no air friction, no terminal velocity (up to light speed anyway). either you missed his saying the thing about the lack of air or he forgot to include it.
ok here's one for your teacher, if you are in a car traveling the speed of light at night and you turn on the head lights, can you see in front of you? if you look in the rear view mirrow, can you see behind you?
loren
11-09-2003 18:57:51
 Re: Re: O/T for you science buffs in reply to rhudson, negating air fri, 11-07-2003 16:12:22
You don't see the light at all because you're moving at the same speed. Like you're not passing the JD if your Farmall is going the same speed.
RAB
11-08-2003 00:39:11
At that velocity, how would you know it was at Night????? ?? Wouldn't you be somewhere else by then/now or whenever.....
Regards, RAB
Steve - IN
11-07-2003 17:35:07
It's not a fact. That science teacher violated Newton's 3rd law and ought to be sent to physics jail. Here's why:
Consider this: Two Apollo space craft, both in the vacuum of space. Both have just slingshoted around the moon. One fires a rocket (pulled the trigger on the rifle) the other does not, and just relies upon Earth's gravity for its return. Which one gets home first? The one that fired the rocket, of course. Both have Earth's gravity pulling them, both are in a vacuum; but the rocket powered one has used Newton's 3rd -- every action results in an equal and opposite reaction --and gets home first. End of story. The speed of the rifle bullet leaving the tube against gravity is about 10 times greater than the speed of the bullet falling to Earth, propelled only by gravity. That's real simple.
Also consider this: Cmdr Dave Scott, on the moon, 1971. Drops a hammer and a falcon feather at the same time. Near perfect vacuum. The feather hits a tad later than the hammer -- greater mass in the hammer. Galileo was right -- 400 years earlier.
Speed of light. We leave Newton and enter Einstein territory. If E=MC squared, then at the speed of light, you're pure energy anyway, and don't see a thing. Assuming you're not pure energy, you neurons don't run faster than light speed anyway, so you don't notice any difference in anything you see from one moment to another, as everything is constant.
rhud
11-07-2003 23:49:18
 Re: Re: Re: O/T for you science buffs in reply to Steve - IN, 11-07-2003 17:35:07
me thinks you are pulling my leg.
the Apollo example has little to do with the bullet example. but, i agree that for every action there is an equal but opposite reaction. in the Apollo example the acceleration of gravity added to the acceleration of the bullet in the opposite direction will increase the average velocity of the capsule.
in the students question, the velocity of the speeding bullet is decelerated by gravity to zero and then accelerated by gravity back to it's high velocity. in the bullet example V initial (after leaving the barrel) will be decelerated to V final (0) by earths gravity (no air ok?) at that time gravity (the same gravity that slowed the bullet) will pull the bullet back to earth. this time V initial will be 0 and v final will be the high velocity. since their is no air friction, the bullet cannot loose energy in any way, only trade kinetic energy for potential energy and then back to kinetic. the time up will be equal to time down, the gravity will be the same the v initial (up) and v final (down) will be the same. the balance of the two formulas is the same. vfinal squared = vinital squared + 2as a = gravitational acceleration (32.2 ft/sec/sec or 9.81m/sec/sec) s = distance traveled. there is no qualifing the formula as to if it is used with gravity or against gravity, only the sign of a changes (either positive or negative)
the feather and hammer thing. the greater mass of the hammer also means a slower initial acceleration by gravity while the feathers lower mass means a faster initial acceleration. the only difference is final force applied by the two objects. the time for the fall is the same. you are correct, in that Galileo observed this experiment, you are however incorrect in that his observation showed both to hit at the same time. (legend of tower of Pisa) he used two spherical objects of the same size but of vastly different weights so that the present air would effect both equally. the formula for time of a fall such as this is: time= the square root of twice the distance dropped divided by the gravity constant. you will notice that neither weight nor mass is associated with the formula. I cannot account for the experiment you mentioned, but will look into it.
if you will remember your scientific history, you will remember that the concept that was the basis of reletativity was a passenger on a train that accelerated to the speed of light. the formula e=mc squared actually uses the speed of light as a quantitative value not qualitative statement. It was the basis of Einstein’s later work, my examples deal with his earlier work. Again I agree with you in that I would not want to go that fast , especially with our roads in Virginia, but again in theory the passenger would both see forward and backward. Speed of light being constant therefore time itself must change as speed changes. if you consider the neurons as also part of the passenger then they are already at the speed of light and any displacement of signals either from the eye to the brain or from the brain to the eye being onlt relative to motion inside the car, not outside.
I know this is tripe to some but it is important to the education of our children. The most complicated events must be simplified and studied before the actual complicated world be explained. that’s why its important to understand bullets in a vacuum before understanding bullets in real world air. By the way, Robert in W. Mi has it correct in that Hatcher did the experiment, for another discussion we could talk about why Hatcher theorized that in a perfect experiment,the bullet would also come back to land on its base not its nose. Man, I love this stuff. and for those that think the deal about doers and teachers, the best acceleration formulas i've ever seen are in The Machiner's Hand Book. you can bet your bottom dollar that machinest that "do" have that book, whether they share their knowledge with a student or not.
Steve - IN
11-08-2003 08:17:10
 Re: Re: Re: Re: O/T for you science buffs in reply to rhud, 11-07-2003 23:49:18
rhud,
No leg pulling involved. The statement on the first post was: "then fall back to the ground, reaching the same speed as when it left the barrel." The descending bullet, like the Apollo with no rocket burn, is propelled by gravity alone. The ascending bullet, like the Apollo with a rocket burn, is propelled by a force far greater than Earth gravity. Vacuum or atmosphere, the ascending bullet initially travels faster than the maximum speed of the descending bullet. Newton's 2nd and 3rd laws hold true. Read down a few posts - I calculated the speed differential between the initial upward velocity and the final downward velocity as about 10:1 using Galileo's basic 32 ft per second per second time relative constant acceleration rate for the downward speed, using 4800 ft as max altitude and holding wind resistance at zero, as in a vacuum.
Galileo was disproving Aristotle in Pisa. Aristotle had said gravity was a differential force relative to weight. Galileo showed that the distance a body has fallen at any instant is proportional to the square of the time spent falling proving that all bodies fall with the same constant acceleration regardless of weight. Galileo's fabled lead and ebony balls actually hit at slightly different times because of Newton's 2nd law that acceleration is inversely proportional to mass.
Move to Einstein and you find a link to the above gravity and mass problems in E=mc* which explains the paradox of how light behaves in relation to gravity and its mass. Light has no "resting mass", but does have motion, and can be bent by gravity, therefore it must have some kind of mass. On your Virginia roads, we've neglected to note that E=mc* dictates that light speed causes an increase in mass. Einstein argued that the laws of physics in a laboratory under uniform gravity are identical to those in a laboratory undergoing an acceleration, and thereby developed the idea of gravitation as spacetime curvature. He found that the gravitational field, like the electric field, should also have mass. Gravity, too, will be a source of gravity; distorted space contributes to its own further distortion.
Einstein reached his new theory of gravitation -- his general theory of relativity - in which gravity is a spacetime distortion. Yet he never did develop a unified theory, as gravity is not integrated with electricity, nor is the weak force and the strong force fully explained. So our children must know that we don't understand how the electricity in our neurons will behave in that lightspeed spaceship - and therefore cannot answer the question. Thanks for picking up on that question I left and giving me the opportunity to talk about what Einstein and Stephen Hawking, et cetera don't know.
rhud
11-08-2003 10:04:13
 Re: Re: Re: Re: Re: O/T for you science buffs in reply to Steve - IN, 11-08-2003 08:17:10
i'll run the numbers tonight if i have time. but i think the foot lb numbers you are using are for a Horizontal flight of a bullet in Air, at least they seem to match what my speer reloading manual says. (remember my premice is no air, no friction). with no friction there is no reason for the bullet to have lost any energy at 3000 ft hoz flight if it does not hit anything. where would the energy have gone? Newton's first law is: I. Every object in a state of uniform motion tends to remain in that state of motion unless an external force is applied to it. so in vertical flight (no air) the only outside force is gravity.
vfinal squared = vinital squared + 2as a = gravitational acceleration (32.2 ft/sec/sec or 9.81m/sec/sec) s = distance Do you deny the formula? has nothing to do with weight or mass and is used in a frictionless enviroment
if you would like and to keep others from knowing how pig head people can be we can continue by email.
Steve - IN
11-08-2003 12:04:23
 Re: Re: Re: Re: Re: Re: O/T for you science buffs in reply to rhud , 11-08-2003 10:04:13
It may be interesting to others if we stay pigheaded and post it all right here! Ha!
OK, let's say vertical plane, no air, only gravity. The amount of force in ft/lbs. on exit from the barrel is say >1300 ft/lbs. (no energy expended to clear the air from the barrel), velocity of the round goes to something in the neighborhood of 3000 mph at the barrel, and the max altitude of the round goes to about 11,000 feet in a vacuum, lifting a 55 gram round, working only against earth gravity. From 11,000 ft to 0 feet at 32 ft/sec/sec (the formula is correct) and weight is irrelevant in falling - (but it is relevant in knowing how far up the round can fly given the power of the explosion). I eyeball it at a about 600 mph when it hits the ground. So the answer to the science teacher is you're wrong, we were going faster when we left the tube than when we hit the ground.
Run the numbers and let me know if you come up with something markedly different, or see some flaw in my assumptions.
rhud, fried brain
11-08-2003 19:01:07
 Re: Re: Re: Re: Re: Re: Re: O/T for you science bu in reply to Steve - IN, 11-08-2003 12:04:23
i may have to look at it monday, i think i've pulled something in my head, besides i don't have any books or calculator here.
while i was bushhoging today, i thought about the comment i closed with, and was afraid you would think it was focused at you. i ment it to be inclusive of myself. i glad you seemed to take no notice.
Steve - IN
11-09-2003 09:26:25
 Re: Re: Re: Re: Re: Re: Re: Re: O/T for you scienc in reply to rhud, fried brain, 11-08-2003 19:01:07
rhud,
Not to worry. I had nothing to do this morning, so went at the numbers a different way -- that is, how high does it have to go with 0 drag to get to something around 3000 fps at the ground. I come up with about 32 miles. Check that number if you will.
Anyway, the best round I found in the ballistics tables at www.remington.com was the 300 Rem Ultra Mag which by throwing out my ballistics formula and simply using ft/lbs. of torque versus the 180gr. weight of the round gets to almost 31 miles. No good, still over 100 fps short at the ground.
Then I started looking for Mama Deuce 50 cal ballistics, didn't find them, but started thinking of bigger guns. Remember the Paris gun the Germans used in WWI with a 70 mile parabolic range. Then the progressive charge gun they designed to shot in France and hit London. Projected ranged was 140 miles. Then remembered Gerald Bull, and it turns out he actually did it. In Nov. 1966 a ~100 foot long barrel super gun shot a 185lb. Martlett to an altitude of 111 miles. Bingo. It can hit as fast as it left. I take it all back -- it can be done, but not with any ol' rifle you're likely to pull off the rack. I'll do a post about the magic of the Martlett approach at the top.
Sorry for makin' your head hurt. Have a good weekend.
Steve
Pete
11-07-2003 15:29:14
Here's another science question.... fire a gun horizontally. That bullit will hit the ground in exactly the same amount of time as a bullit dropped from the gun barrel??
Pete
RAB
11-08-2003 00:48:30
 Re: Re: O/T for you science buffs in reply to Pete, 11-07-2003 15:29:14
Of course it will. Gravity only acts towards the centre of mass (centre of the Earth). Horizontal velocity is only slowed by air resistance (and/or hitting something). Gravity will act identically on both the fired and dropped object.
Regards, RAB
Steve - IN
11-07-2003 15:06:52
Take away that guy's teaching license. The powder charge exerts far more force than gravity. If that weren't the case -- the round would never leave the end of a vertical rifle barrel.
Somebody has never read about Galileo dropping balls off the tower of Pisa or Isaac Newton sitting under the apple tree -- and hasn't learned some basics of physics. Gravity works at a constant rate of acceleration, with specific gravity or mass and wind resistance being the only variables at altitudes under ~ 6 miles. A falling body accelerates at 32 ft/sec per second, or slower with wind resistance and lower mass.
Knowing that, we can do the experiment by writing on a napkin. Take your standard issue M16 rifle over to Iraq and fire it straight up at Saddam on a magic carpet. The GI 55 gram FMJ round leaves the tube traveling at 3240 feet per second or 2209 miles per hour with about 1200 ft/lb's of energy at the muzzle and 180 ft/lb's of energy at 3000 feet. As we've missed Saddam so far, the round travels a little under 4485 ft up (180 ft/lbs of energy on 55 grams at 3000 feet spec less wind resistance) before it loses all energy - literally stops for an instant - and then becomes exactly same kind of thing that Galileo dropped from the leaning tower in Pisa. From 0 feet per second at its peak, gravity makes it accelerates at Newton's 32 ft/sec per second until acceleration is neutralized by wind resistance. It works out to a maximum speed of about 307 feet per second, or 210 miles per hour.
Also, think of it backwards. If this "teacher" were right about the bullet - a piece of hale dropped from a cloud at 8000 feet, even with its lower mass, would still hit your head at something over 1,000 mph - and you'd see dead bodies on the sidewalk every time a hale storm rolled through.
RAB
11-07-2003 12:53:22
You can easily try it with a shotgun. Its easier to hit yourself with birdshot (on the way down) as there are so many of them. It will feel like rain or hail. You may have to take into account the wind factor to get it to land around you. Don't try the direct route as a comparison, though - and don't use anything bigger than about 2.5mm diameter shot and don't look up (eye protection needed). Skeet shot size would be even better to try, but you might not recognize it as hitting you when it comes down!!
As some of the other posts said, terminal velocity is variable, object to object. A solid slug from a 12 guage would probably make a big hole in your head due to higher velocity and extra mass. It's not exactly rocket science, but think how quick you run out of range with a shotgun. That's due to air resistance slowing the shot in the horizontal plane (unaffeced by gravity).
Regards and be safe, RAB
TimV
11-07-2003 12:38:33
Nope--in fact, it wouldn't even come close to terminal velocity unless it was fired pretty far up in the air. If this were true, a baseball player would have to catch a pop fly that would come down with the same force as it had when it left the bat--not an attractive proposition! One of my dim-witted (actually quite bright, but with a TERRIBLE destructive streak!) college buddies would fire his 12-gauge into the air straight up, and then stand there and listen to the pellets falling down throught the leaves. He even got hit by a few, but they had hardly any energy left--not even enough to cause a welt.
49 Cubber!
11-07-2003 11:59:30
When you do finally break down and try this to see whos right,watch out for airplanes!;)Just kidding!
Chris
11-07-2003 10:56:44
I did a report in school on this-long time ago. In the 1940s the military did extensive research to see if "falling" bullets could cause injury. They found that if the bullet was actually fired perfectly straight up it would eventually stop, reverse and gravity would pull it down all the while maintaining its gyro effect that keeps a bullet stabilized. Therefore the bullet would fall tail first causing enough drag to slow it down below fatal velocity(I bet it would really hurt though!)They decided if the bullet fell point first it would have enough velocity to cause injury but not death with the exception of a direct head shot. Your teacher was quoting what is known as urban legend, science proves otherwise.
Robert in W. Mi
11-07-2003 13:12:42
 Re: Re: O/T for you science buffs in reply to Chris, 11-07-2003 10:56:44
"Hatchers Notebook" i believe is the name of the book that list all the test, Hatcher (General Julian Hatcher i believe) did to confirm this. He went out onto a big lake, fired straight up, and timed the bullets ect.. He did many test for the military.
I have the book, but it's been many years since i read it!!
Robert
rhud, is that the one
11-08-2003 00:17:36
 Re: Re: Re: O/T for you science buffs in reply to Robert in W. Mi, 11-07-2003 13:12:42
it that the one that he did all the weird stuff to the garand rifle to try to get it to blow up? like stopping up the barrel and firing multiple rounds down it?
JMS/MN
11-07-2003 12:25:12
In paratrooper training they told us that terminal velocity was about 120 mph. Found out in the dictionary that it depends on the type of falling body: "the constant velocity of a falling body, attained when the resistance of air, water, or other surrounding fluid has become equal to the force of gravity acting upon the body. The terminal velocity for a man is about 120mph (e.g. for a parachutist delaying the opening of his chute); the corresponding velocity for a cat is proably 40 mph at the most (Newe Scientist). So if a bullet is smaller than a cat, it must have a much lower TV than the cat. I always thought that terminal was the same for any object.
Garry
11-07-2003 13:58:26
 Re: Re: Re: O/T for you science buffs in reply to JMS/MN, 11-07-2003 12:25:12
I remember in college physics our teacher told us that the terminal velocity of a man falling would be around 110 mph (the teacher was small in stature) so I guess the average would be around 120 mph. I didn't remember much from that class but that one stuck with me for some reason. i never wished to test this however.
Steve - IN
11-07-2003 15:48:31
 Re: Re: Re: Re: O/T for you science buffs in reply to Garry, 11-07-2003 13:58:26
Garry,
Your teacher never read about USAF Capt. Joe Kittinger who rode a skyhook balloon 102,000 above New Mexico then jumped. He reached a maximum velocity of 625 mph (not quite supersonic), as he fell for nearly a minute before encountering any significant atmosphere.
He opened his chute at around 50,000 feet and walked away smiling when it was all over.
Science teacher
11-07-2003 10:33:57
Hi all, I am a physical science teacher. In theory it is correct, however, that is assuming no air resistance. In real life, the friction with air will not allow it to reach the same speed. As mentioned earlier, every object has a terminal or maximum velocity when falling. It depends on how much friction it has with the air. Since a bullet is small and very dense it would reach a pretty high velocity and I would not want it to hit me as it came down.
Just my .02 worth.
Steve - IN
11-07-2003 16:18:58
 Re: Re: O/T for you science buffs in reply to Science teacher, 11-07-2003 10:33:57
Science teacher,
The 0 atmosphere assumption requires 0 gravity (gravity being the stuff that holds atmosphere), so that assumption is about as valid as the proverbial wings on pigs = flying pigs.
If the round is copper, which has a specific gravity or mass of ~8.5, the effect of the round hitting you would be the roughly equivalent to 8.5 same size drops of rain hitting you in the same place in the same time -or- or 1 rain drop propelled by gale force winds (water having a specific gravity of 1.00 by definition). As I know of few deaths from rain in gales, much less hurricanes -- I think you'd survive, and wouldn't even suffer penetration of your skin.
RAB
11-08-2003 01:02:05
 Re: Re: Re: O/T for you science buffs in reply to Steve - IN, 11-07-2003 16:18:58
Steve,
You are wrong in your assumption that zero gravity is synonymous with zero atmosphere. For instance the moon has gravity (has mass) but no atmosphere. The atmosphere is, indeed retained by gravity but this is not the only criterion. For instance, hydrogen molecules in the Earth's atmosphere can escape to space because they can have enough kinetic energy (as velocity) to do so. The rest (gases) are held OK (or the Earth would never have had an atmosphere and we would not be here..... )- just food for thought.
Regards, RAB
Steve - IN
11-08-2003 09:48:56
 Re: Re: Re: Re: O/T for you science buffs in reply to RAB, 11-08-2003 01:02:05
RAB,
The moon does have gravity and it does have an atmosphere. The Apollo program identified helium and argon atoms there, and Earth-based observations added sodium and potassium ions to the list in 1988. Promise it's true, look it up.
Only space with zero gravity will never attract an atmosphere -- therefore in any natural, non-artifical, state; the 0 atmosphere assumption must be accompanied by 0 gravity -- and the whole thought exercise becomes tautological, as the bullet would never fall.
Just for fun and games, though, let's say that the slight moon atmosphere has near zero effect, and that there is enough earth oxygen stored to light the powder in the shell. Fire the rifle and measure its speed as it leaves the muzzle versus its speed when it returns to the moon's surface. Use a fudge factor of about .2 to account for the difference between Earth and Moon gravity. Run the numbers and I think you'll find the muzzle speed is about 10 times greater than its speed when it hits the moon -- proving the original statement wrong -- the force of gunpowder is greater over the same time and space than the force of earth or moon gravity. So rockets do fly, and you can get to the moon.
Now leave the moon, and go to Jupiter. Do the same experiment with the same rifle, knowing that Jupiter has over 300 times the gravity of earth. The round barely leaves the tube and the science teacher is happy to have found a place where gravity is stronger than earthbound sized gunpowder rounds.
RAB
11-09-2003 01:26:47
 Re: Re: Re: Re: Re: O/T for you science buffs in reply to Steve - IN, 11-08-2003 09:48:56
OK, OK. I give in! Yes you are right about the moon, But REMEMBER Newton's Law of Universal Gravity says all mass has gravity. Now consider deep space - not much there, but you would occasionally come accros an atom or molecule, but we don't consider that deep space is anything but empty normally. Also consider a meteor - it also will have some gravitational effects but would probably not have an atmosphere around it even though there may be some gas in it. Also consider the asteroids floating around our Solar System - they tend to evaporate a bit on nearing the Sun and leave these bits behind as a tail. Yes, science is not quite as black and white as we generally make out and we still don't know what is at the bottom of those Black Holes, etc etc etc..... !!!!
Regards (and going to sleep on this thread now), RAB
Steve - IN
11-09-2003 13:41:51
 Re: Re: Re: Re: Re: Re: O/T for you science buffs in reply to RAB, 11-09-2003 01:26:47
RAB,
I think on the asteroid, the bullet never returns, because escape v = sqrt(2GM/R). For the largest asteroid I can find, that means <1000 mph velocity. A decent rifle round will leave the tube traveling at 1500 to 2500 mph with earth gravity. So, bye bye, it's gone. The moon's escape velocity is ~ 5000 mph.
When it comes to black holes, I give up. Far more theory than fact is known about them.
BUT
I did think about the problem a lot more, and just to make you happy; posted a solution above under the name: IT CAN BE DONE. Hope you find my solution a bit intersting and amusing.
Steve
BB
11-07-2003 10:18:21
Every falling object has a terminal velocity. That velocity is a function of the force of gravity against the repelling force of the coefficient of friction of the air. That coefficient of friction is different for all objects and directly determines how fast the object will be falling when it reaches the ground. Think of a man falling with a parachute and one without. A bullet leaving the average high powered rifle will be traveling 2500+ fps (1700+ mph) or over twice the speed of sound. It will not be traveling that fast when it comes back down.
Rufus Windrow
11-07-2003 10:18:10
Unlike the rest of you fellas who are just figurin' from the seat of yer pants, I actually saw Pinapple Jim Henry do this in '47 just outside Jakes Corner, Yukon. We never really figured out the terminal velocity but it sure did leave a big terminal hole in old Jim's head.
David
11-07-2003 09:56:47
I don't think this is correct. The energy from the explosion of the shell is directed to push the bullet out of the barrel of the gun. When the bullet stops moving upward it will then come to a complete stop, for a fraction of a second, and then gravity will be the only thing accelerating or forcing the bullet back to ground. Once termanal velocity for an object falling back to gound is reached that is it. An object can be propelled by other forces faster than gravity can.
One way to try it, not recomended though, is to fire your gun streight up into the air next to a shead with a tin roof. You know what would happen if you fired the gun streight up under the building. See if the falling bullet has the same affect.
I have done this with a compound bow, the arrow falling back to ground will not go punch a hole in the tin roof.
mike
11-07-2003 09:45:47
Believe the teacher to be incorrect. Velocity upwards has little to nothing to do with eventual velocity downwards. When it starts to fall, it will increase that rate exonentially until a maximum is reached or it strikes another object. Can't remember what the max is, but the rate of increase is something like 12 meters/sec. (Haven't had physics for about 20 years.)
RayP(MI)
11-07-2003 13:48:09
 Re: Re: O/T for you science buffs in reply to mike, 11-07-2003 09:45:47
No, the science teacher is correct: The figure you're looking for is 9.8 m/sec/sec. This is approximately 32 feet/sec/sec. This represents the acceleration due to gravity here on earth. The same gravitational force works on the bullet whether it is going up or down. So, if we exclude the friction due to the fact that the bullet is traveling through an atmosphere the theory holds: The descending bullet would be traveling at the same speed as it left the muzzle, only in the opposite direction. In our world, air resistance would slow the bullet somewhat, and probably somewhere in flight, the rotational energy would diminish, and the bullet would probably begin to tumble, increasing the air resistance, and thus slowing the descent, somewhat. HOWEVER, the speed of the falling bullet would be significant, and I'm not about to attempt this experiment, not even with a hard hat on!
Here's another scientific curiosity - if you fired a projectile straight upward from a MOVING vehicle, and the vehicle continued to travel at the same velocity and direction, would the falling projectile hit the vehicle? Theoretically, the answer is YES. I'm a science teacher too, and my students and I launched hobby rockets off the roof of a moving car. Came awfully close to getting hit several times. Had there not been a slight breeze, I'm sure it would have.
Chris
11-07-2003 14:12:15
 Re: Re: Re: O/T for you science buffs in reply to RayP(MI), 11-07-2003 13:48:09
I think your missing something here. When the bullet leaves the muzzle its being propelled from the explosion in the gun at a rate that temporarily overcomes air and gravity- moving as fast as 4000 feet per second. Once the bullet peeks it only has its own mass being pulled by gravity minus air resistance. Its terminal velocity would not even come close to the muzzle velocity. I do agree that trying this experiment would be pretty stupid.
old
11-07-2003 09:38:01
in thoery its fact, but in thoery a some bees can't fly
Les...fortunate
11-07-2003 09:24:35
In theory, your teacher is correct. There are so many variables that, in actuality, it probably never would happen.
Ben in KY
11-07-2003 08:57:29
Once the bullet expended its "upwards energy" it would merly be a falling object with a maximum terminal velocity, which would not be near muzzle velocity.
I could be wrong though :)
