Tractor Talk Discussion Forum
ford tw-15 water in oil
kirk
11-15-2003 16:12:48
this tractor has 12000 hours, 2000 since rings,bearings, found water in the oil today, alot. about 2 gallons, started this pretty suddenly. motor seems to have partial skip. should I suspect head gasket, or does this 401 have wet cylinders? any help apprecitated.
kirk
Woodbeef
11-16-2003 14:40:06
 Re: ford tw-15 water in oil in reply to kirk, 11-15-2003 16:12:48
Well I'd wager that at least one of your cylinders is now a wet one..... ..All kidding aside I'd say you have the dreaded bane of non-sleeved engines.....pin holing..... At least it can be bored out and dry sleeves inserted.
paul
11-16-2003 10:02:26
I saw your question somewhere else with a reply from Bern. He's the Ford guy, worked on them for years.....
As you are hearing, most likely cavitation pinhole with those hours.
--->Paul
IanC
11-15-2003 17:57:32
401's are parent bore engines like all other '65 and up units. If you're EXTREMELY LUCKY it will be the head gasket, but it's more likely that it's a pin hole into the cooling jacket from cavitation corrosion. If I remember correctly the TW5/15/25/35 have the new style block, which is still available if you can't find a salvage one. Pull the pan, fill the cooling system and look for drips, you probably won't even have to pressureize the system to find them.
