Tractor Talk Discussion Forum
John Deere 1520 diesel cdc fuel pump
John
11-15-2003 16:40:24
My CDC 33 Stanadyne doesn't pump fuel any more.
It was working just fine the other day.
The dealer says i have to get a replacement pump and can't rebuild this one.
Any suggestions?
Thanks
david val
11-15-2003 23:25:05
 Re: John Deere 1520 diesel cdc fuel pump in reply to John, 11-15-2003 16:40:24
as mentioned, look for a good diesel shop for the possibility of repair. if replacement is required look for a used 'b' pump and rebuld it, or for a rebuilt one.
david
Mike
11-15-2003 17:56:50
If the tractor has an electrical shut off and not the pull rod.Listen and or feel the fuel pump when the key is turned on or off. Shut off solenoids are a common problem with this pump.You should be able to hear or feel the fuel solenoid click. If not the solenoid is bad. For a temporary fix, the solenoid can be removed, the plunger and spring taken out and the solenoid reinstalled. You will have to stall the tractor to shut it off. Parts are available to repair this pump,but are hard to come by.Some of the larger rebuilders may have NOS parts in stock,don't limit yourself to Deere.
