Tractor Talk Discussion Forum
rumley mystery
nf owen
11-16-2003 18:01:13
gentlemen, where on a small rumley is s/n tag or i.d.? flywheel casting is c5p4256, front axle c5p4264, pushrod cover c5p4138. what is she? no mag, no oiler. be blessed
nf owen
11-17-2003 08:29:35
 Re: rumley mystery in reply to nf owen, 11-16-2003 18:01:13
philip, sir, u r a blessing. like yourself, i am not nearby this machine. i wes saturday. my relatives. i understood all answers except the depression area. what & where is that? i did see the diff lok pedal are there lots of these made. probably all that was wrong, it broke a rocker arm. what is your machine? these are my favorits, behind steam, which i aint got. do got as russian airplane, though.
Philip Anderson
11-17-2003 17:58:37
 Re: Re: rumley mystery in reply to nf owen, 11-17-2003 08:29:35
NF What I am referring to is at the very front of tractor you will see Rumely in raised letters. Under that is a loop that you can hook on to, below that is a inverted ball shape or depresion perhaps to hold a wagon tongue. Look for a flat spot on the edge of the depresion. this tractor is probably a model L 15-25 hp or a model M 20-35 hp built 1924-27. 4,855 model L were made and 3,671 model M were made. My Rumely is a model X 25-40 hp which was converted from a model M. Dad bought it in 1963. Philip
Philip Anderson
11-16-2003 18:59:58
NF, I think you have a light wieght or a super powered. There are three places to look for S/N. First place to look is on rocker arm cover this plate may be missing. Next spot is in front above the loop and depresion. next place is by the steering wheel rod, you may Have a foot pedal for locking your diferential by it. also the engine has one near the cover plate by the water tank. Look for S/N to start with a L-M-R or an S for a light wieght or a W-X-Y or Z if it is a super powered do a search for rumely you can find a site that list S/N. Philip
Philip Anderson
11-17-2003 04:36:08
 Re: Re: rumley mystery in reply to Philip Anderson , 11-16-2003 18:59:58
I think i made a mistake with the front S/N. It may be under the depresion. Look for a flat spot in that location. My rumely is in another state so i can't look to be sure.Philip
