Tractor Talk Discussion Forum
cost of operating a block heater
Mark
11-17-2003 12:49:25
My tractor has a heating element installed in the block which warms the water and makes it crank easy. I need to crank it every afternoon. Should I keep it plugged in all the time or should I get a timer, or should I make a special trip to the barn to plug it in in the mornings. In other words how much electricity does that thing use?
arthur
11-17-2003 21:00:50
 Re: cost of operating a block heater in reply to Mark, 11-17-2003 12:49:25
block heaters are cheaper than starter repairs and battery replacement . when you start it's ready to go in short order the cab heater will start putting out soon also.
Ray,IN1
11-17-2003 19:59:00
I use a switched recepticle(access in house so I stay warm) to turn on 2 hrs before I want the tractor. Tractor is ready to start in coldest weather, and the rest of the day the tractor will start without the heater. Some plugin timers are rated for 1000 watts and cost around $25. It is not necessary to leave the heater on 24/7, but it's your tractor and money.
rhudson, x.10
11-17-2003 16:36:55
our electricity is around $0.11 per kilowatthour. i use a x10 control system to turn my heater and lights on from the house. if your shed electricity is from your house beaker box it will work. just plug a x10 receiver in at the shop, plug the heater into the receiver. plug a transmitter into an outlet at your house. by activating the transmitter it will turn on the heater. try X10.com for all the neat stuff you can do.
thurlow
11-17-2003 15:36:31
Mark; sorry that I don't know wattage of my heaters or electricity rates, but..... my tractors (that I use in winter time) with crankcase heaters use about 20 or 25 cents worth of electricity per day, plugged up whenever they're not running. Tractors with block heaters (water jacket) use about $1.25 electricity per day. I put a timer on them which comes on about 3 hours before expected use. Can't afford the $40 per month. Tractors crank equally well with either type heater. You'll hear some folks say you'll fry your engine oil with crankcase heaters; maybe so, but a couple of these old tractors have 12-15,000 hrs and I'm not aware of any problems. Not all tractors are equipped for crankcase heaters and the price of them is about 4 or 5 times what you can expect to pay for block heater..... ...I'd buy a $15.00 timer; just make sure it'll handle the wattage of your heater.....
Stu
11-17-2003 15:03:27
Balance a couple bucks extra a month against messing around with battery chargers,jumper cables and ether on a 0 degree morning with a 30 mph wind blowing when you really need the tractor.My chore tractor and skid loader stay plugged in all winter. Don't notice much of a difference in the electric bill,what with the house heat,fountain heaters and shop heater running
Bob
11-17-2003 13:05:15
Do you know the wattage of your heater?
Typical range is 600 to 1500 watts.
As an example, 1000 Watt heater operated for 1 hour = 1000 watt/hours = 1KWH. Assuming electric rate of $.01 per KWH gives you a cost of $.01 per hour. Substitute your actual wattage and electric rate for an exact figure.
If the tractor is stored inside out of the wind, it may be possible to switch to the smallest heater you can find for your application, and leave it on all the time.
The other alternative is to use a high-wattage heater and a timer set to come on a couple of hours before you typically need the tractor.
There are advantages to both. The big heater with a timer is probably your cheapest operating cost, but if you have the luxury of having the tractor out of the wind, and use a small heater always on, the tractor is ready to go anytime. I have a 4020 with a small heater in an unheated polebarn, and I keep it plugged in most of the winter. Sure is handy when you need it at a moment's notice, such as when a neighbor slides in the ditch!
Frank
11-17-2003 13:04:38
The energy usage in kwh can be figured by multiplying the power rating of the heater by the time of operation. For example, 800 watt is 0.800 kw, so if this 0.800 kw heater were "on" for 2.0 hours it would use 1.6 kwh. I don't know what your electric rates are, but it seems that it would take a while for the savings to pay for a timer purchase.
I have always just plugged my heater in an hour or so in advance of starting and it has worked so far.
Drill
11-17-2003 16:39:19
 Re: Re: cost of operating a block heater in reply to Frank, 11-17-2003 13:04:38
If you use your tractor at the same time every day, I would get a timer and set it for about 3 hours before you start. This will save electricity and you heater will last longer.
IHC Red
11-18-2003 01:48:31
 Re: Re: Re: cost of operating a block heater in reply to Drill, 11-17-2003 16:39:19
Good Point. They will definately burn out faster if they're left on all the time.
