Tractor Talk Discussion Forum
calcium cloride in a 11 x 28 tire
sjh
11-21-2003 15:47:36
I am putting a new tube in my tire. How much should I put in, and what is the mix ratio?
Thanks
Scott
IanC
11-21-2003 19:08:33
 Re: calcium cloride in a 11 x 28 tire in reply to sjh, 11-21-2003 15:47:36
Instead of chloride you should use the new product "Rim-Guard" it's a by-product of sugarbeets, and is non toxic and non corrosive. It's within a fraction of a pound per gallon of chloride, and only slightly more expensive. And no, I don't make the stuff, but we did change over to selling it in our cable plows and trenchers as it won't harm a customers lawn if it leaks out.
marlowe
11-21-2003 18:50:34
i have 150 gal. you cane have for FREE yes FREE!!!!! !!!!i don't need it in my pulling tractor. i'm in wisconsin hope you are to. and it will [NOT] hurt your tire or rim and will only if you have a leak and your tractor will ride better with it over weights
sjh
11-22-2003 06:41:18
 Re: Re: calcium cloride in a 11 x 28 tire in reply to marlowe, 11-21-2003 18:50:34
Sorry I am in NY. Wish I was closer.
Alvin NE WI
11-21-2003 17:38:21
I disgree with the other 2 people. The stuff does no harm if you take care of your tires like a good person should. If you plan on driving with leaky tube than you will have a problen several years down the road. It is not a easy task to bull around with 150# weights several times a year. If you put several sets on you will take out door frames and trees near fense. I have 2 tractors here with calcium clorde in since '56 and have no problems, even rims look good. I also have a '38 tractor that sat in shed with calcium for last 30 years and rimes are perfect. I don't have a book handy now but that size tire would use about 20- 25 gallons.
Rod (NH)
11-21-2003 17:33:07
Hi Scott,
Well, I'll actually answer your question :o). Here's a chart that will give you the volume for each tire. For the 11.2x28 that is about 27 gallons per tire. For the concentration, here's a pdf file from DOW (see page 2) that provides for various concentrations in lb/gal. I use 2 lb/gal. That will prevent freezing down to +10 deg F. Below +10, ice crystals will begin to form a slush but the solution will not freeze solid even at much colder temperatures. I have never had a problem in forty years at tempertures getting down to -20 deg F. Some will say to use 3 or 3.5 lb/gal. You be the judge. I just think it is not necessary for anything warmer than -20 deg F. By the way, that concentration is when using 77% flake CaCl. I will add also that I always use tubes and monitor and replace valve cores when necessary (that's not often). I have never had any rust problem at all using CaCl in, as I say, some 40 years in two tractors, one of which has it in the front tires also. Misuse and/or abuse though and rusted rims can be the result but I suspect you already know that.
third party image Rod
sjh
11-22-2003 06:46:39
 Re: Re: calcium cloride in a 11 x 28 tire in reply to Rod (NH), 11-21-2003 17:33:07
Thanks Ron. That is what I was loking for.
Ron 1456
11-21-2003 16:36:18
Forget the calcium cloride and find some cast iron weights if you need more weight. The only reason for using fluid in tires for weight is cost. In the long run weights will be cheaper and your tractor will ride better and last longer. Calcium cloride solution in tires has been obsolete for a long time and has never been a good idea.
george md
11-21-2003 18:30:21
 Re: Re: calcium cloride in a 11 x 28 tire in reply to Ron 1456, 11-21-2003 16:36:18
Use the calcium , it's cheaper and it keeps
the tractor from bouncing like a rubber ball
when tire has only air.
george
js
11-21-2003 17:08:12
I 2nd the motion
buickanddeere
11-21-2003 20:33:19
 Re: Re: Re: calcium cloride in a 11 x 28 tire in reply to js, 11-21-2003 17:08:12
We pumped the calcuim out of the antique tractor collection and working tractors ecept for the loader tractor. The salvage yards are full of ruined rims from less than 10 years old. Why work around a problem when it can be eliminated? By the way our tractors don't bounce.
