Tractor Talk Discussion Forum
4010 power steering
Kevin
11-25-2003 05:54:54
I have a 1961 John Deere 4010D. The power steering does not seem to be working well. It takes alot of effort to turn the steering wheel to the left and quite a bit to turn it back to the right, but not as much as to the left. It gets some what easier after it warms up but never works like it should. The steering motor underneath the fuel tank area has a leaky seal and I have changed the hydraulic oil and filters twice having found water in the system and I'm going to have to do it again. Any Ideas? Thanks.
david val
11-25-2003 10:55:17
 Re: 4010 power steering in reply to Kevin, 11-25-2003 05:54:54
is your rockshaft working properly? check pressure and flow at the remote. if ok, disconnect steering motor drain line at the oil cooler and plug the cooler nipple. start engine an turn steering a few times full right and full left while watching the drain hose. if at any stage there is an oil flow bigger then a drip from the drain hose then the steering motor needs resealing. if not, the problem is probably in the steering valve.
Kevin
11-26-2003 05:07:51
 Re: Re: 4010 power steering in reply to david val, 11-25-2003 10:55:17
David Val,
Thank you for the info!!
Kevin
