Tractor Talk Discussion Forum
UTB 445 DT 4 wheel drive slips
David
11-26-2003 16:20:46
I hope someone can help with this problem I have run into on a UTB 445.
When under load with the 4 wheel drive engaged the drive shaft to the front axle stops. I am wondering if anyone hase any experiance with this.
it would seem that there is some sort of slip clutch. can you confirm this and how can it be repaired. thank you for your time.
marlowe
11-26-2003 19:59:25
 Re: UTB 445 DT 4 wheel drive slips in reply to David, 11-26-2003 16:20:46
ok the last long i had apart the front spline was rounded out on the drive shaft near the trans.
marlowe
11-26-2003 18:23:39
well i think that every one would like to know what is a UTB 445 ? so hear goes what is a UTB 445 ??. then some one might be able to give you a hand. i for one have no clue what it is. might be just stupid me.
geok
11-26-2003 18:29:32
 Re: Re: UTB 445 DT 4 wheel drive slips in reply to marlowe, 11-26-2003 18:23:39
They are better known as a Long 445 or Universal. Built under patents from Fiat. Generally made in Romania.
Can't answer your question why the front axle quits turning. May not be completely engaging.
David
11-27-2003 00:15:49
 Re: Re: Re: UTB 445 DT 4 wheel drive slips in reply to geok, 11-26-2003 18:29:32
I have removed the drive shaft at the transmission end and put two bolts in the output shaft flange.
then with the tractor in gear and 4wd lever engaged, used a 45 cm lever and with about 4o to 50 lbs applied to the lever the flange turns. it feels as if it slips then grabs. when it slips there is no noise to indicate damaged splines or gears. Also worth noting when you drive the tractor you can see the shaft turn and then stop turning and then turn again as if it is some sort of overload clutch fault but i dont have a workshop manual on this tractor and not sure if it
even has an overload clutch for the 4 wheel drive.
