Tractor Talk Discussion Forum
to20 clutch
frank
11-27-2003 03:02:39
Clutch will not initially disengage. Once I work with or force into gear all works well. If I start in gear it's like the clutch has no affect until forcefully geared. Is this a clutch, trans, or hyd problem?
frank
RAB
11-27-2003 14:52:29
 Re: to20 clutch in reply to frank, 11-27-2003 03:02:39
It's a clutch problem. Have you set the clutch linkage as per specifications?
Regards, RAB
Alvin n Ms.
11-28-2003 06:05:45
 Re: Re: to20 clutch in reply to RAB, 11-27-2003 14:52:29
Sounds like the clutch plate is sticking to the flywheel, when parked. I would try slipping the clutch and burning off the oil, rust, whatever is making it stick. I have been there and done it lots of times.
