Tractor Talk Discussion Forum
pto adjustment
mike
11-29-2003 05:29:51
how do you adjust the pto on a oliver super 55 any help would be appreciated
Kenny
11-29-2003 07:40:20
 Re: pto adjustment in reply to mike, 11-29-2003 05:29:51
There is a plate with 4 bolts on bottom of transmission. About where foot plates are.
Inside is your PTO Clutch, has a notched adjustment nut. Roll PTO Clutch arround till you find Spring loaded pin in one of the notches. Depress pin & turn adjustment nut clockwise about 3 notches ( I use 2 flat blade screwdrivers) and see how lever works may need more??
Once you get it to click in and out next Question is will it hold??? If it will not hold under load you will have to split tractor & replace clutch disks.
If you get into more than adjustments probably will need a Shop Manual. If I can help just let me know. I'm in the process of rebuilding a 550 Gas right now. So I have the tools & parts & shop manual strung all over the wife's garage.
jake
11-30-2003 08:01:19
 Re: Re: pto adjustment in reply to Kenny, 11-29-2003 07:40:20
The PTO engagement lever when adjusted should snap and lock at 32-35 pound pull, this insures proper pressure on the plates also the grease zerk [lower right under foot rest] should greased every 5 hrs when in use.
greenbeanman
11-29-2003 06:56:26
Are you asking about adjusting the clutch for the PTO? I'm not into Olivers, but I can't think of any other adjustment that would be made.
