Tractor Talk Discussion Forum
Help identify
Randy Belcher
11-30-2003 16:08:57
My husband recently bought this small tractor at an auction. It has this on the plate.
Model F Cub
Serial #59494
I need to know what it is, how old it is and where do I start restoring it.
If anyone can help I'd appreciate it.
Sandra Belcher
wdTom
11-30-2003 17:08:47
 Re: Help identify in reply to Randy Belcher, 11-30-2003 16:08:57
You ask a simple question with many answers. It all depends on the condition of the tractor and what you want it to be. Basically though the first thing is to make sure you don't do any more harm. That is how I try to approach working on things, DO NO HARM. So you want to get an owners manual and repair manual. Next you want to change ALL the lubes in the tractor and grease every fitting on it. There is no telling when this was done last. Change the engine oil and filter, steering box oil, transmission/rear end oil, final drive oil, and PTO oil if it has one, and the hydraulic oil if it has hydraulics. Change the coolant and fill with a 50/50 antifreeze mix. Look at the belts for cracks. Change the fuel filter or clean the strainer. At least look at the points, possibly installing new points and condenser, cap and rotor, and plugs and wires. It all depends on the condition. You might want to remove the front hubs and clean and regrease the front hubs too. And check tire pressures. Now when all this is done you can use the tractor and it won't do itself any damage. But it might need other repairs too, you did say restore. It could need engine work, power train work, painting, etc. What you do depends on how you want the tractor to be. A good working tractor, even if the paint is shabby, or a show tractor that looks better than the day it left the factory. As for how it runs, for occasional use it doesn't have to run really great, just run OK, what do you want? But get manuals, it will be the best money youspend on the tractor.
CH
11-30-2003 17:38:01
 Re: Re: Help identify in reply to wdTom, 11-30-2003 17:08:47
WD, What are you doin? It's the guy's wife. You should be telling her it was a great buy. You should also say that he should get a new 3/4 ton pickup and gooseneck trailer and a keg cooler and a new huntin gun and a new recliner. Come on, help the guy.
Forgot the big tv.
wdTom
12-01-2003 16:57:26
 Re: Re: Re: Help identify in reply to CH, 11-30-2003 17:38:01
Well I think you took it wrong. Getting manuals is a first if you have to ask "what do I do now", even if you know tractors a manual can keep you from making a mistake. And as for lubeing the tractor, that costs little, and can go a long way towards preventing any damage while you decide to do or not do anything else. Also changing all the oils is a good way to be pokeing around the tractor learning about it. The tune up stuff,with a manual most should be able to handle that, except for maybe the points and condenser change. I would say a manual may even say how to clean the fuel strainer. And what does it being his wife have to do with it? She could be interested in learning about tractors, there are women who are. Or she could just be posting for him, passing on the information to him. Either way I standby what I have said in these two posts. What do you recomend? Feel free to give her better advise, maybe she will take your advise instead of mine, as she should if yours is better.
Gary Duff
11-30-2003 16:29:12
You have a Farmall Cub made in 1949,very nice little tractors.
Sandra Belcher
12-01-2003 18:50:51
 Re: Re: Help identify in reply to Gary Duff, 11-30-2003 16:29:12
Thanks for the info. Other replys say I need a manual, but when I clicked on the manuals on this site, it's like chinese to me. What next? Do I just go to a tractor place and tell them what I need?
Help!!
SBelcher
terry
12-11-2003 07:23:04
 Re: Re: Re: Help identify in reply to Sandra Belcher, 12-01-2003 18:50:51
you can go to the tractor dealer or to the library they seem to have most of them.that is where i got mine till i found one to buy
