Tractor Talk Discussion Forum
Snow Plowing w/ Back Blade...
Nick Trimbee
12-01-2003 08:56:17
Grateful for any tips on plowing a rock-dust drive with a 5' back balde on a workmaster601 (chains & filled tires -- location New England). Is it best to plow in reverse or plow forward and push/pack in reverse, does blade need wax to stop snow sticking, etc? Thanks a bunch for any info.
Nick
12-02-2003 11:27:18
 Re: Snow Plowing w/ Back Blade... in reply to Nick Trimbee, 12-01-2003 08:56:17
Thanks for all the advice, guys!
Nolan
12-02-2003 05:39:21
Good luck. I've done it with that exact combination, and it's not fun or particularly effective. Just a few feet of snow built up on the sides of the drive and you can no longer move the fresh snow. A 5' blade also isn't as wide as your tractor, so you're packing it down with the tires, and getting stalled.
Reversing the blade keeps you from gouging the driveway as badly, but it only works if there's a few inches of snow down. Neither forward or reversed make the blade actually lift the snow, it's just shoved sideways a bit.
If I had to do it all again, my preference would be first for a snow blower. If not that, at least a front mounted lifting type snow blade. Both of these get the snow up and over.
farmered
12-02-2003 03:41:16
Try some spray silicon on that blade. A little sprayed in your boots makes them pull on easier too, no kiddin. Ed
rod
12-01-2003 17:59:45
first call you chiropractor and set up the appointments you will need for neck and shoulder problems if at all possible consider a front mount set up of some sort much easier to see what you are pushing and much easier on the neck.
regards
rod
Larry NE IL
12-01-2003 17:54:54
I've always used a back blade or drag box. I never push in reverse, except to get to tight places or pile snow. If you've got a good one coming, don't wait 'til you've got 3' on the ground! Like the post b4, keep your speed up with the blade angled. If you can tilt the blade so that the cutting edge is behind the top of the blade, do it. It will make it less aggresive and you won't plow all your drive stone up with the snow. Overplow or you will run out of room in no time. I drag mine straight out, then push into a stockpile in reverse. Good luck, Larry
TomH
12-01-2003 14:51:53
As the others have said, experiment to find what works. We generally keep the blade mounted forward (curve side to the front) and push most of the snow in reverse at an angle across the drive, then clean up going forward.
MapleStone
12-01-2003 11:05:53
It really depends on the type of snow and the depth. You'll have to experiment a bit to find what works best for you.
A couple hints I can give you is;
1 Don't be afraid to go fast. If you have a long drive that you can get up some speed this helps keep you moving and kinda throw the snow off the blade. Now I'm not talking road gear here but get the thing movin.
2 If you are going to drive forward angle the blade as hard as you can in one direction. You will quickly learn why you have individual breaks when doing this. You will want to ride the inside (not the side the snow is leaving the blade) brake to help keep going straight.
Personnally I would only pushed backwards if you have a drift or want to push up your banks. Other than that we would go forward.
And start plowing wider than your drive way if you live in a place that gets lots of snow. If you don't you will end up with a pretty narrow driveway buy the end of the winter or you will have to try to move frozen banks.
And again I will say "Go Quick" it is probably the best advice I can give. Other than "Buy a Snowblower", pushing is better than shoveling but blowing is best.
Hope this thread gives you some ideas.
Let us know how you make out after your first big snow.
KURT
12-01-2003 09:13:04
I never used a back blade, but I watched my neighbor do it with an older ford 3000 with rear 3pt. blade. For smaller snow, under 6" it seemed to work okay with the blade angled. The heavy snow would seem to clog the blade and just pull the mess in behind the rear tires. (messy) I would think that plowing in reverse with the blade reversed would work best, just drive backwards and every 20-30 feet just push it into a pile. Of course having a front blade works best I think.
Steve Mahler
12-01-2003 09:11:21
No Wax needed in my experience. With stone drive I think it best to start the year pulling the blade forward. This is less likely to dig in to gravel, and should create a snow base. After your base is hard and frozen, you can go either way. I usually run in reverse because you dont drive over the snow first, and I can push it into big piles that way. In deep snow, you definately have to go in revers since it will be hard driving through the deep stuff - especially turning.
Tip - try to turn your whole body sideways on the seat - it takes 'some' of the strain off the neck!
