Tractor Talk Discussion Forum
Snap'n Turtle tree puller
Walter
12-01-2003 15:58:03
Has anyone ever heard of a Snap'n Turtle tree or stump puller that mounts on a 3PH? It was made in Texas by Caldwell Mfg, who is no longer in business.
Nolan
12-02-2003 05:33:21
 Re: Snap'n Turtle tree puller in reply to Walter, 12-01-2003 15:58:03
A stump puller takes a tremendous amount of tractor to be able to pull it straight up out of the ground. You got enough machine?
Cliff
12-01-2003 21:36:44
Walter Please be carefull about pulling stumps with anything attached to your 3 point hitch. I met a guy in an ER a few years ago that was lucky to still be here. His 8 N went over on top of him doing the same thing.
I bought a used stump grinder that mounts on the tractor and have found it much faster and also easier on my tractor clutch. IT does not leave a stump hole.
Even been asked to do some for the folks around the area for cash. Guess a guy could make a few bucks with one. If he had the time.
Good Luck
Cliff
EddieV in MD
12-07-2003 11:30:34
 Re: Re: Snap'n Turtle tree puller in reply to Cliff , 12-01-2003 21:36:44
Where did you get your stump grinder for your 3 pt hitch? How much was it? have you made any side money with it grinding? A guy around here charges $1.00 per square inch of stump.
Walter
12-02-2003 08:00:17
Cliff, Thanks for your comments. The 3 point lift only serves to tighten the jaws. The stump pulling would be a function of tractor forward motion, not lift. The device would pull low enough that it would be below the centerline of the rear axle, so I won't be lifting the tractor front end.
onlytony
12-01-2003 17:55:07
If you mean it was made in Caldwell Texas, I live
close to Caldwell and I could ask around. If so
do you know when it would have been made ?
Nau
07-21-2005 20:02:55
 Re: Re: Snap'n Turtle tree puller in reply to onlytony, 12-01-2003 17:55:07
The caldwell was the name of the company. It was E.L. Caldwell & Sons from Corpus Christi, Texas. The company was sold at a bankruptcy auction in 1985 to several different buyers.
Walter
12-02-2003 07:55:14
Tony, I'm not sure how old it is, but it's not an antique. I think the company went out of business not that long ago. Any help would be great.
