Tractor Talk Discussion Forum
5.9 Cummins coolant drain
Van
12-02-2003 16:23:07
Can anyone tell me where to drain the coolant from the block of a 01 5.9 Cummins diesel? I have the Dodge maintenance books and they are very vague and do not show the location, I found the radiator drain and can't locate the one on the block. Thanks in advance.
Van
Leon R
12-02-2003 19:15:29
 Re: 5.9 Cummins coolant drain in reply to Van, 12-02-2003 16:23:07
When I did mine on my 94 I pulled the lower rad hose as well as opening the drain cock. Make sure you have a large tub/container to catch the fluid. Also replace the coolant with the correct Fleetguard coolant for the cummins engine.
Van
12-02-2003 19:29:58
 Re: Re: 5.9 Cummins coolant drain in reply to Leon R, 12-02-2003 19:15:29
Thanks Leon, I couldn't find a plug anywhere on the side of the block except below the water jacket. Maybe there aint one.
Van
