Tractor Talk Discussion Forum
thermo-siphon cooling system
Charles Houston
12-03-2003 10:05:37
About to assembly my little Avery after restoration. When I premix the radiator coolant what type of water do I use? Should I use distilled water or what? Thanks for your help.
jake
12-03-2003 10:13:14
 Re: thermo-siphon cooling system in reply to Charles Houston, 12-03-2003 10:05:37
Use only distilled water, well and city water are loaded with minerals and water from a water softener are warned against by all due to ionization.
raytasch
12-03-2003 10:12:02
Charles, It depends on the mineral content of the water you have available. If you have known good mineral free or very low content water you would probably be safe using it. If you have high mineral content water use the distilled stuff. For less than a dollar a gallon I go for the distilled stuff to mix the antifreeze. What is a couple a bucks more to do it right? (G)
ray
