Tractor Talk Discussion Forum
Smoke signals! Sticky Rings?
Chris
12-05-2003 07:05:30
I have an Allis 160 with a Perkins diesel. After it has sat for a while (couple weeks/months) it smokes a lot out the breather and exhaust. It will clear up some after she warms up. I suspect the oil control rings are sticking. Anybody have suggestions on how to cure this problem? TIA,Chris
Allan
12-05-2003 10:10:56
 Re: Smoke signals! Sticky Rings? in reply to Chris, 12-05-2003 07:05:30
Chris,
I agree with 'another chris'. I think that tractor needs to be put to work. Should clear it right up.
Allan
Another Chris
12-05-2003 09:42:22
I have this problem with some of mine after they set for a while. Mine are all gas but I take them out and pull the guts out of them and it usually clears up. Sometimes it take a little Seafoam in the crankcase. It will free up engine parts and you can really tell the difference.
dfarmann
12-05-2003 16:43:20
 Re: Re: Smoke signals! Sticky Rings? in reply to Another Chris, 12-05-2003 09:42:22
Cris; Please explain to me what Seafoam is and were you get it? I have an 806 with the same problem because it don't get used for Bull work anymore. TIA Dave
hay
12-05-2003 08:19:40
you might try using a heavier weight oil or an oil additive. also the problem could be leaking valve stem seals. if it keeps on smoking after trying the heavier oil, the then only real cure is to go into the engine and overhaul it.
