Tractor Talk Discussion Forum
Allis WD Fluids
Martin Miller
12-05-2003 14:16:03
I will very soon be buying an Allis Chalmers WD. What should I do to the tractor before I use it much? What kind of engine oil should I use for it? What kind of transmition oil do I use? Does the transmition oil take care of the PTO? How much oil does the engine take? Transmition? I really appreciate any help.
Archie
12-06-2003 08:03:52
 Re: Allis WD Fluids in reply to Martin Miller, 12-05-2003 14:16:03
Hello Martin. I would change all fluids.Don't forget the final drives. My book says use sae 40 above 90 degrees. Above 32 use sae 20. above 10 degrees use sae 20 w. Below 10 degrees use 10w. That is for the motor. I use 10w30 in mine all time in missouri no problem. It holds 6 quarts. Transmission holds 17 quarts. 18 quarts with pto. Use sae 80ep all year.The final drives hold one and three quarters quart each. use sae 80ep all time. Clean out breather cap, clean air cleaner bowl and fill to mark with same oil as in motor. Hydraulic uses sae 20w. There are three drain plugs one on bottom of transmission, bottom of differential and bottom of clutch housing. Drain all three or you will have dirty oil left in side. Good luck. Archie
Brian G. NY
12-06-2003 16:58:34
 Re: Re: Allis WD Fluids in reply to Archie, 12-06-2003 08:03:52
Be sure to use non-detergent 20 wt. oil in the hydraulics or if you can't find that, most people nowadays use a good hydraulic oil.
JMS/MN
12-05-2003 14:33:18
All that and much more is in the OPERATOR (Owner) manual. Good investment to learn about your purchase.
Martin Miller
12-05-2003 14:37:17
 Re: Re: Allis WD Fluids in reply to JMS/MN, 12-05-2003 14:33:18
Where can I buy an operators manual for an Allis Chalmers WD?
John (C-IL)
12-05-2003 19:38:50
 Re: Re: Re: Allis WD Fluids in reply to Martin Miller, 12-05-2003 14:37:17
Your local AGCO dealer can supply you with NEW factory original manuals for your WD.
I Like Case
12-05-2003 16:18:30
I just checked 'Allis Manual' on eBay. It looks like they are going for $8.99 + shipping. I would also take a look at Amazon.com.
