Tractor Talk Discussion Forum
Bent Crank????
CH
12-06-2003 20:06:17
Just got the pistons out of a stuck 125CI Allis B engine. When I turn the the crank there is an uneven amount of resistance at 180 degrees rotation. Does this sound like a bent crank?
Thanks for the help.
sod
12-07-2003 18:28:35
 Re: Bent Crank???? in reply to CH, 12-06-2003 20:06:17
As long as you have it tore down this far, rebuild the whole thing to specs. You will be happy.
regrind the crank, etc.
good luck
sod
ErnieD
12-07-2003 08:59:58
Loosen one journal at a time until you find the egged one, bet it is too tight.
cole in mo.
12-06-2003 23:45:09
it could be a bent crank, but I would pull the timing cover and check for rust on the cam gear or in the govener.
Ch
12-07-2003 05:34:58
 Re: Re: Bent Crank???? in reply to cole in mo., 12-06-2003 23:45:09
I've got the govener out. Had to looser the bearing clamps on the crank to get it to move at all. I tightened the center one and that didn't tighten the rotation, but if I torq either end clamp I still get a different resistance in rotation. I can hardly turn it for maybe 30 or 40 degrees. I oiled the bearings, being carful of the shims, but it didn't make a real difference. Seems to me it should spin easy with no pistons in it. By the way, this is my first rebuild.
wdTom
12-07-2003 13:52:07
 Re: Re: Re: Bent Crank???? in reply to Ch, 12-07-2003 05:34:58
Shimming bearings is not a fast easy thing. It will take time and fitting of parts to come out right. You need to have the proper amount of "crush" That is, with the bearing shells in place, shims in place but bolts not more than finger tight, you need to be able to insert the proper feeler gauge into the gap between the bearing cap and block or rod. If with the proper cursh you still have too much bearing clearance (plasti gauge it to see) well now you neeed to carefully and evenly file the bearing shell and reduce the shim thickness by the same amount to maintain the proper crush. It takes time. Look in your manual for the proper cursh. Have you done this? With the proper clearance bearings can seem to grab or have seized up if you don't turn the crank for a while, but when you break it free it should rotate freely and start again after you let it stop for only a few seconds or a couple of minutes.
CH
12-07-2003 18:47:14
 Re: Re: Re: Re: Bent Crank???? in reply to wdTom, 12-07-2003 13:52:07
Thanks Tom. I pulled the crank, it needs turning. My manuals are on the way. Thought I'd get started. I keep finding new things. The vanes in the oil pump were stuck and the water pump was a little rough. I've got a lot of time before this little tractor has to run. I bought a package deal, '39 on rough tires but together and a '41 parts tractor, most of it is there. That's the engine I'm working on. I figure rebuild the worst first, especially since in parts it fits into my cellar shop. I figure if'n I'm gonna do this I might as well make it last another 60 years. That way I won't have to rebuild it again 'till I'm 107.
I'll be buggin you veterans for help for a while. Hope ya don't mind.
Charlie
RAB
12-07-2003 11:33:23
You may regard this as a stupid suggestion, and it may not be possible, but are the mains caps on the right way round and in their correct positions?
Have shims been removed to take up clearance and left the crank tight due to ovality? (more likely on big ends).
Regards, RAB
CH
12-07-2003 12:05:49
 Re: Re: Re: Re: Bent Crank???? in reply to RAB, 12-07-2003 11:33:23
I think you might be on to it. As long as I've got the engine down this far, I'm going to pull the crank and mic it out. The farther I take it down the more glad I am I did. Just took the oil pump out and the vanes were stuck. Might as well take it to the bare block and rebuild it from the bottom up.
