Tractor Talk Discussion Forum
trailer brakes
roger
12-08-2003 14:21:42
I am trying to buy a used tag-along equipment trailer. One unit has "vacuum over hydraulic" brakes. Could someone tell me how these work, specifically, what is needed at the truck/trailer hook-up. Also, they seem to be old technology; are they dependable?
snowey
12-08-2003 17:22:13
 Re: trailer brakes in reply to roger, 12-08-2003 14:21:42
Vacum brakes are smoother in braking ,more reliable than Elec.no wires magnet to replace , some say slower than air if they are slower not by much Vacum brakes was used on most and the largest trucks untill air brakes came in to use about 1950 . Good system , best brakes for under 15,000 Lb. if your pulling truck did not have air brakes
Ron 1456
12-08-2003 18:08:06
 Re: Re: trailer brakes in reply to snowey, 12-08-2003 17:22:13
I prefer air brakes over all the others but snowey is right. If the truck doesn't have air brakes the trailer can't have them. Vacuum brakes are better than electric brakes.
roger
12-09-2003 07:18:21
 Re: Re: Re: trailer brakes in reply to Ron 1456, 12-08-2003 18:08:06
Thanks: The web site for the kits talk about the need for a vacuum pump. Can I not tap into the existing vacuum booster on my truck?
thurlow
12-08-2003 14:54:25
You'll need a control unit under the hood and a vacuum source; manual override in the cab; two vacuum hoses to rear of truck with connectors; got mine from Redline( hhttp://www.tjtrailers.com/store/vacuum-hydraulic-kits.html; or do a search for Redline trailer brakes); personally like vacuum/hydraulic better than electric.
