Tractor Talk Discussion Forum
elongated holes in rim
terry
12-09-2003 08:32:45
I am restoring an old tractor that was run a short distance with loose lug nuts. The holes
in rim are close to an inch in diameter with a beveled edge. Finding another rim is not very likely, so what are my options?
I can build up the edges with a wirefeed welder and grind off, but my concern is keeping all the holes exactly centered, that seems like the tough part!
My billfold won't allow me to take it to a machine shop.
Brokenwrench
12-09-2003 16:19:52
 Re: elongated holes in rim in reply to terry, 12-09-2003 08:32:45
Check with some local dealers,parts stores,or tire dealers for larger outside diameter nuts. I have bought 1/2 thread lug nuts that take a 1 1/8 socket. Many other sizes are available.
Nebraska Cowman
12-09-2003 11:06:02
Just use washers with the nuts. Retighten them several times and you should be "good to go" Had the Duals come off a Chevy truck one time. broke several studs. I put in new studs new nuts and carried the wrench in the cab. Hauled silage and tightened them every load for a day or two till they stayed tight. pitty the poor fool that ever has to remove them!
Rod (NH)
12-09-2003 09:31:24
Hi Terry,
Here's one possible solution. Gemplers has 5, 6, 8, 9 and 10 hole rings available.
third party image Rod
terry
12-09-2003 20:49:35
 Re: Re: elongated holes in rim in reply to Rod (NH), 12-09-2003 09:31:24
Can someone tell me what gemplers are and where do I get them.
thanks a bunch guys
Joe
12-09-2003 19:07:38
I've got these on the front of my ol' chevy dually. I only use it for heavy work like hauling hay or gravel or wood, so I don't go that fast...about 60 or so. They work great. Good luck!
rustyfarmall
12-09-2003 12:07:15
I like that idea a whole lot better than the one I was trying to figure out how to explain.
Ben in KY
12-09-2003 09:37:31
Rod,
That would be my recommendation as well.
RAB
12-09-2003 09:21:36
Are there no alternative holes you can use? My steel rims are drilled with lots of holes for various lug patterns and I have just used more appropriate holes. Are the bevels wear, or for a countersunk head?
What percentage of lugs were run loose? If 100%, I would possibly drill new holes and electric weld these ovals in completely (afterwards), as my welding would not be as easy to drill as the original rim. Make a jig so that all holes can be aligned as carefully as possible - the time spent will be worth it!
If only a few, then repair. Fill in and start again, enlarge and weld in a bushing, or whatever you feel happiest doing.
As an amateur, I would probably use a 'practool' for enlarging 13mm holes to that size, while using a power tool of limited wattage.
Hope this helps.
Regards, RAB
