Tractor Talk Discussion Forum
center pivot tires on tractor
terry
12-09-2003 21:05:54
Is there anything wrong with using new tires,that
are intended for center pivot, on a tractor that is being restored. They are 4 ply BFG, 14.9x24,
$140 each.
Only thing about appearance is, it says irrigation
on the side of them and the lugs don't look quite as heavy although they are close.
paul
12-10-2003 05:46:37
 Re: center pivot tires on tractor in reply to terry, 12-09-2003 21:05:54
You get what you pay for with this. You are saving about $200 for the set, but will get a lot less wear or 3pt load capacity from them - kinda poor choice for real use.
Or have a few questions now & then about the lettering if this is just a parade tractor. That may or may not be worth $200 to some people, but the tires should hold the rear end off the ground if that is all the tractor does. :)
--->Paul
