Tractor Talk Discussion Forum
difference between case 3294 and 3394
zoidberg
12-12-2003 15:07:42
What is the difference between these two models ? (the 3294 and 3394) They are listed at the same weight and horse power. What is the difference? Thanks.
doug@upr
12-12-2003 17:12:38
 Re: difference between case 3294 and 3394 in reply to zoidberg, 12-12-2003 15:07:42
the 3294 is basically a juiced up 2290-2294, except the 3294 tractors were all equipped with fwa, either a zf or carraro axle (the carraro axle is a much more reliable axle, though not as sharp turning). also the 3294 was only equipped with 1000 pto, though many have been converted to dual pto since a pto would easily convert over from a 20-2290,94. the 3394 is basically the same tractor tractor design way back to the 12-1370 tractor with some minor upgrades up through the 90 & 94 series. the only real difference from the 90 to the 94 series is the electronic control powershift, which made for a much more reliable trans, since i was not as easy to abuse.
also the 94 series had the option of a 24 speed powershift, and a dual pto is not available for these tractors.
almost forgot, even though both tractors have the 504 case motor and maybe pumping out the same horsepower, the 3394 has a much larger journal crankshaft, believe it or not but the 3294 has the same crankshaft that was used way back to the 930-1030 era.
zoidberg
12-13-2003 05:56:52
 Re: Re: difference between case 3294 and 3394 in reply to doug@upr, 12-12-2003 17:12:38
Thanks, this is good to know. The 3294 looks a little less appealing now.
Red
03-19-2004 20:17:57
 Re: Re: Re: difference between case 3294 and 3394 in reply to zoidberg, 12-13-2003 05:56:52
Are you fellows tuned in on the rest of the 94 series.4994,4894,4694,44949
(ferris_les@hotmail.com)
