Tractor Talk Discussion Forum
1988 Long 460 tractor
Alan Johnson
12-13-2003 20:00:33
While breaking land recently with my 460 long tractor, the 3pt lift became sluggish and would lift only when engine was at full throttle. I checked the hyd. oil and it was milky so I changed it and cleaned the filter. This seemed to help but still the lift is not 100%. Is the problem the hyd. pump? If so, what kind of pump is required?
A Johnson
12-14-2003 13:11:07
 Re: 1988 Long 460 tractor in reply to Alan Johnson, 12-13-2003 20:00:33
Yes, the equipment stays up when tractor is shut down, even overnight. I probably should change the filter because it is the original. It did have a leak under the seat around that large nut with a brass washer on it . I tightened the nut and the leak stopped. I guess I need to be looking for a hyd pump. Any info would be appreciated.
geok
12-14-2003 05:37:07
Does implement stay up after you shut down the engine? When you cleaned the filter, did you make sure both rubber seals were still on both ends of filter? Sometimes these seals come off and plug the intake and starved the pump. If filter has been in machine for more than 5 years, it is best to replace it.
Pumps are available from Long dealers and from aftermarket tractor parts dealers as well.
