Tractor Talk Discussion Forum
hydraulic oil
Johno
12-16-2003 00:54:35
Can deisel fuel oil ,be used as substitute for hydraulic oiltempory .Info please ,Johno.
Kennyp
12-16-2003 10:17:44
 Re: hydraulic oil in reply to Johno, 12-16-2003 00:54:35
Temporary only....won't "score" if it does not have grit. Problem is its too thin (low pressure)and biggest problem is it will foam like crazy. Only if you have to.... like maybe to get a loader home.
paul
12-16-2003 05:37:33
Not at all.
Some people have used ATF for a very brief period to flush out crud, but even that is hard on the system. Diesel would have all the wrong properties all the way around, just real bad idea.
--->Paul
John K
12-16-2003 19:22:12
 Re: Re: hydraulic oil in reply to paul, 12-16-2003 05:37:33
We only used ATF in our Case 830 hydrolics. Never had any problem in both tractors.
NO NO NO
12-16-2003 03:11:57
If you want to ruin the pump and possibly score valves
