Tractor Talk Discussion Forum
Your Opinion
Allan
12-16-2003 09:22:05
Hey Guys,
I'm thinking very seriously about putting electric heat in my garage. The garage measures 28' x 30' with 9' walls. I'm frantically putting in the insulation now.
I had a guy out this morning from the local heating and air conditioning store and he says that they build these heaters for folks all the time. It would be a 10K watt heater incorporating a furnace fan, would run off of 220v and be digitally controlled via a thermostat on the wall.
The local druggist here had one of these things put in a like-sized garage and he swears by it. He says it is very economical.
You guys ever hear of anyone doing something like this?
Thanks,
Allan
JF
12-16-2003 19:46:52
 Re: Your Opinion in reply to Allan, 12-16-2003 09:22:05
Just put in a LP heater that hangs 1 in from ceiling for $590 includeing vent pipe.
Works very well.
John K
12-16-2003 19:17:47
Here in Alberta the trend is to use gas fired infared tub heaters. Many bussiness are switching over to this type of heating from regular forced air heating, some have paid for the switch over in one year from the savings. I put one in my shop that has a 9 foot ceiling. Mounted it at a 45 to the ceiling. I work in the shop in a t shirt at 30 below even if the door is open as it heats the objects (me included) instead of the air. It is the objects that in turn heat the air from conduction.
KURT (Mi)
12-16-2003 16:18:12
Well it would cost me about 82cents per hour to run it, Ouch. Could you put in a wood stove or a regular forced air furnace.
Ray
12-16-2003 15:01:45
We use a fuel oil furnace,have for 20 years,
probably the most economical,cheaper than
propane and more BTU's per gallon.I wouldn't
even consider electric,very expensive,takes hours
to heat up a building.I can turn my fuel oil
furnace on and in 30 minutes its warm in my 40x70 shop.
Mark in MO
12-16-2003 14:07:27
Allan, GE makes a Heat Pump/Air Conditioner that will both heat and cool your garage. GE'S P/N is AZ55H15DAB. These are available @ W.W Grainger. Grainger's P/N is 1VG93. These List for $1,420.00
but if you have an account# you can use the cost is 18-20% less. I have a old farm house that is at least 100 years old. The foundation of the house is very thick laid rock, because of how the house is constructed, and because I didn't want to knock holes in the foundation, I put two of these in my house. One would have probably worked to heat and cool my 1,350 sq foot home but because of how it's laid out, I put in two. These work very well. If you are interested, e-mail me and I'll get you more info.
Mark Hill
Dearborn,MO
Allan
12-16-2003 11:44:29
Yesterday I found the 'mobile thermostat' that I was looking for and it works quite well with this 175K BTU space heater.
My thinking was to use this thing to bring the space up to temp and then just use the electric to 'maintain' the heat while I was working out there.
I'm probably not going to be putting in a large amount of time in the garage, just when I have a project of some kind going on.
I dunno,
Allan
paul
12-16-2003 11:24:55
Electric is generally the most expensive heat. It can be cheaper to install, but do you have all the electrical in already, will need another circut.
Here in Minnesota we have fairly cheap electrical rates, but very cold, no one can afford electrical heat on a regular basis. If you only use it 1 day a week over winter, might pencil out. You'll have to dig out your local numbers, but as others say, be aware of the large bills you will get if you use it often.
--->Paul
Red Dave
12-16-2003 11:14:44
Depends on how much you want to use it. Also depends on electric vs fuel prices in your area. Around here, electric heat is cheap to install, but is relatively expensive to operate. Propane is more expensive to install, but operates at less cost per BTU.
If you are going to use it everyday all winter, a good, vented propane heater would be my choice, with the understanding that it probably won't break even the first winter. If it's a once and a while thing, I'd probably lean toward electric.
heat pump?
12-16-2003 10:09:57
You might chck into heat pumps. Think they cost more, but might save on electric bill if you run much. When I built a little 10 x 12 tool room, I found a used unit from a motel for 10 bucks. Has cooler and reverses plus a heater element for heating. Works great and the cooler is nice in the summer.
Dave_Id
12-16-2003 09:35:17
Unless you are a major stockholder in your local power company, I would think a propane heater would be far more economical to run.
Willy-N
12-16-2003 09:28:27
Adverage electrical cost is .10 KWH so you will be looking at aprox 1.00 a hour to opperate it when it is running. For me the math is not that hard to figure out. I have a electric infer/red heater that I can turn on if needed but I wear warm cloths most of the time. Mark H.
steveormary
12-16-2003 09:48:10
 Re: Re: Your Opinion in reply to Willy-N, 12-16-2003 09:28:27
Allan, If your house is all elect. you may get a special rate. If your garage will be well insulated elect.heat may be cheaper then propane. Depends on where you live. Will you be doing any kind of work in the garage? A warm place to work is nice.
steve
