Tractor Talk Discussion Forum
Horsepower 1951 JD B ?????
JD B
12-21-2003 11:23:42
How much horsepower is possible with a 1951 JD B ?????
buickanddeere
12-21-2003 22:02:06
 Re: Horsepower 1951 JD B ????? in reply to JD B, 12-21-2003 11:23:42
The lettered two cylinder Deeres in particular we built to plow all day while running on the cheapest stuff oil refineries would sell. The small dia, long heated ports make low rpm torque and burn oil in a low compression spark ignition engine. High rpm$ and HP co$t bucks to radically modify an engine design.
520-LP
12-21-2003 19:13:18
We have a 52B with a power block, a heisler and manifold that is around 50. Its for sale
MeanGreen
12-21-2003 12:15:04
27.6hp gas stock with a 4.69 engine
24.6 drawbar hp and kerosene is about 21.1hp probably double that with good parts
hope that helps.
JD B
12-21-2003 12:25:57
 Re: Re: Horsepower 1951 JD B ????? in reply to MeanGreen, 12-21-2003 12:15:04
Is 75 - 80 HP possible?????
MeanGreen
12-21-2003 13:07:33
 Re: Re: Re: Horsepower 1951 JD B ????? in reply to JD B, 12-21-2003 12:25:57
you can stroke and bore it and use alum. pistons,longer rods and put a fabed cast iron spacer between the block and the crank housing. upgrade clutch discs for more pulling torque.
but i think 60-70 should be possible with all that but you might have to spend spend some $$$$.
i got 80 drawbhp out of a G but i think they'll hit 100 stroked with $6000 in it.
