Tractor Talk Discussion Forum
Tractor Starter Question
JKC
12-21-2003 16:48:38
I just got my starter "rebuilt" at the local start expert's place. Spent plenty of time hooking the thing up (twice now) only to find that it engaged the flywheel one time and cranked a little bit, then stopped and would do no more. When I checked on it, I could see that the starter gear is still engaged with the flywheel gear. What would make a starter gear NOT retract, away from the flywheel, like it is suppose to? I need to know if this starter genius "stiffed" me, or if this is something I can fix. I would appreciate ANY ideas!
Trucker
12-23-2003 22:56:51
 Re: Tractor Starter Question in reply to JKC, 12-21-2003 16:48:38
All of those were good answers,it might be that the drive wasnt installed right,or its the wrong one.
Greasy John
12-22-2003 09:05:51
sounds like maybe a new brush hung up?? What was the original problem that caused the rebuild? If it acted the same maybe you have an intermitant in the field windings the guy didnt catch.
bill
12-21-2003 20:29:07
Sounds like it mat have a drive with one more tooth than the original and making it bind Its opssible the armature shaft is already bent as this can happen Sone drver are 8 teeth and some 9 teeth dwpending on application
marlowe
12-21-2003 18:55:09
first you did not say what type of starter? some will only retract after the tractor starts the turning of the fly wheel pushes the drive back and the others are pulled back by the cellunoid
Howard Yoshida
12-21-2003 18:54:52
Aloha, I think there should be a spring to push the gear back after the engine starts. Is the spring there? Some automobiles have shims to adjust the spacing between the starter gear and flywheel. I don't know if this would apply to your engine but if it does, then it needs to be adjusted. Hope this helps.
Mahalo,
Howard
Nebraska Cowman
12-21-2003 17:33:08
check and see if it ain't binding someway. could be a bad drive.
