Tractor Talk Discussion Forum
Re: Valve Springs
Wayne
12-23-2003 18:56:02
Jim, you don't say what kind of engine your working on here. For the sake of helping I'll assume it's a small engine of some type. Some brands have a compression release made in with the cam. It's designed to keep the intake open long enough to get the engine spinning over fast enough to start easy. At a certain speed centrifugal force takes over and kicks it out letting the valve close and the engine actually start. Like the other posts said you may be able to find a spec for the spring and test it (in some cases only if you have the right tools. It could also be the seat has worn enough to close up the clearance between the valve and lifter which will cause it to remain open. In this case you can usually grind the valve stem to regain the lost clearance. Hope this helps.
