Tractor Talk Discussion Forum
Parts for JD 2010 gas Utility Industrial tractor
Bill
12-24-2003 10:48:44
Looking for a good salvage yard that would have 60's rear tire hub part number T15351T for a JD 2010 gas utility industrial tractor. If you can help please email me. Thank You. Bill
Bill
12-29-2003 04:36:38
 Re: Parts for JD 2010 gas Utility Industrial tract in reply to Bill, 12-24-2003 10:48:44
Tractor is a 2010W.
fasting
12-25-2003 17:48:03
Is the hub the same as the 2010 Ag utility, on a pressed steel rim? About 14.9x28 tire? Those were
heavy hubs. Yards don't toss out much Deere iron,
if you post your state, probably save on killer
shipping charges. The 2010 diesels were problems,
so an Ag model can more easily be found. They
were about 9 or 10 bolt, model 2010 RU. Difficult
to just drop random names throughout N. America.
Kindly help with your location. Good luck.
Bill
12-26-2003 03:22:48
 Re: Re: Parts for JD 2010 gas Utility Industrial t in reply to fasting, 12-25-2003 17:48:03
Not sure about the Ag vs. RU models. I need to look at this weekend. The yellow tractor/loader/backhoe hub that is cracked and worn out is the bright yellow tractor color and not an agriculture green or pale yellow color. This hub has the pointed square spline taper end on one side and is flat on face even with the rim on the other side which fits on a 29 inch spindel. I know there is a similiar hub that is the same square on one side but the outside face instead begin flat with the rim, points out similiar to the inside hub and fits on a 33 inch spindel. I have already replaced the spindel, but still looking for the hub. I will have to get more details. I am located in Pennsylvania and already tried Wensingers locally. The best information I have is the hub stamped number.
