Tractor Talk Discussion Forum
Farmall H Axle Housing
Linda Kinney
12-26-2003 06:41:25
Does fluid from the differential flow into the axle housings, or are the axle housings dry? My husband and brother are working on a 1950 Farmall H. Thanks!
Jon
12-26-2003 14:31:45
 Re: Farmall H Axle Housing in reply to Linda Kinney, 12-26-2003 06:41:25
We need some more info here. My H is leaking at the right axel only a few years after a new seal installation (had to open to replace a bearing)and it is definately not overfilled with oil or water. Maybe one of the "FARMALL" board guys will chime in to help. Jon
Howard Yoshida
12-26-2003 14:51:49
 Re: Re: Farmall H Axle Housing in reply to Jon, 12-26-2003 14:31:45
Aloha, If it has a breather hole, maybe it clogged building up excessive pressure. The axle could have a groove in it so if the new seal lip goes over the groove, it will wear the new seal or the new seal will not seal as good.
Mahalo,
Howard
CRUSADER
12-26-2003 11:46:35
Hey it's been a while since I tore into an H or M Farmall. But if memory serves me right, You will get very little gear oil inside of the axle housing. The inner bearing will get lubricated well enough from the gear oil in the transmission and rear end. The outer bearing, best pack it with wheel bearing grease and give it a shot or two of gun grease when you use it. Hope this info is correct and helps you out.
later days mate,
Jim
Linda Kinney
12-26-2003 17:08:05
 Re: Re: Farmall H Axle Housing in reply to CRUSADER, 12-26-2003 11:46:35
Your replies contained the info my husband needed.
Thanks to all of you for your help.
RLS ia
12-26-2003 07:03:15
I have three H,s around here and all are leaking on one side or both, so the oil gets up there somehow. They do have grease jerks on the outer part by the seal retainer.
T213R
12-26-2003 12:33:06
 Re: Re: Farmall H Axle Housing in reply to RLS ia, 12-26-2003 07:03:15
Willing to bet that if there is fluid inside the axle housing, enough to cause leaks, then that rear end is well overfilled with fluid. I'll bet that either the rear end has a lot of water in it, or there is a fluid leak from somewhere else. I'm not sure as to whether the rear end on a Farmall. and it's transmission share fluid or not, I'm used to JD.
just me
12-30-2003 19:29:20
 Re: Re: Re: Farmall H Axle Housing in reply to T213R, 12-26-2003 12:33:06
yup, probably right....i worked on a guy's super 88 oliver once...hyd pump seals..i was changing trans and rearend fluid..book said 18 quarts..i drained out 11 gallons!!!
