Tractor Talk Discussion Forum
640 Ford Tractor
Phillip Hunt
12-27-2003 19:28:50
My 640 Ford tractor when when pulling up hill it starts to miss and will die if the clutch isn't pushed in and the tractor is stoped. It acts like it is starving for fuel. If you are driving it in the level or you are going down hill it does fine. Any suggestions on what might be wrong with my tractor.
Dennis D.
06-21-2005 08:02:32
 Re: 640 Ford Tractor in reply to Phillip Hunt, 12-27-2003 19:28:50
I had to adjust the float in my carb. It was set way to low. This solved my problem.
old
12-27-2003 20:13:20
Try putting more fuel in the tank, when going up hill its is not getting enough fuel for it to run well I have the same problerm at times
