Tractor Talk Discussion Forum
Need a Quick response
CH
12-28-2003 16:32:35
Think it's OK to put WD40 in the cylinders for the winter or just streight oil. The WD is more convenient. Engine is free and I won't get back to it till spring.
Rawleigh
12-29-2003 13:42:18
 Re: Need a Quick response in reply to CH, 12-28-2003 16:32:35
For twenty years I have "pickled" the 440 Chryslers in my boat by slowly pouring Marvel Mystery Oil down the carb until they choke out. REMEMBER TO POUR IT SLOWLY OR YOU CAN HYDRO LOCK IT! It has worked well for me. They belch a cloud of blue smoke when you crank it in the Spring, but there is no corrosion or stuck rings. Rawleigh
Jim.UT
12-29-2003 14:30:06
 Re: Re: Need a Quick response in reply to Rawleigh, 12-29-2003 13:42:18
Chrysler 440 in a boat? Geez! How big a boat is that?
Rawleigh
12-30-2003 07:23:53
 Re: Re: Re: Need a Quick response in reply to Jim.UT, 12-29-2003 14:30:06
Twin 440's in a 1966 Bertram 31 Sportfish & yes they do burn a lot of gas!!
rhudson
12-28-2003 18:24:59
like others have said, wd-40 probably not good for this purpose. if you want a spray in..there's a spray product call "engine fog" maybe. i think i got a can from john deere dealer but i'm sure napa or maybe chinamart has it.
CH
12-28-2003 19:30:12
 Re: Re: Need a Quick response in reply to rhudson, 12-28-2003 18:24:59
You know, I got a can of engine fogger in the cellar. Never thought about that. Use it on my boat.
CH
12-28-2003 17:18:28
Thanks guys,
Didn't know what would be better. Got 4 squirts of Castrol GTX and a few cranks on the crank.
D.L.
12-28-2003 16:44:41
I agree with the previous post... wd 40 will evaporate... after it seeps past your rings & into your engine oil... creating a big mess. I would use something like an upper lube, or marvel mystery oil, etc... squirt in thru the spark plug hole & turn engine over a couple of times... maybe put in a squirt more, then replace plugs. BE SURE TO LOOSEN PLUGS & CRANK ENGINE OVER A FEW TIMES BEFORE RESTARTING!!! Liquid in the cylinders will not compress and will most likely crack pistons if you don't blow out as much as possible (by cranking with the plugs out) before starting.
rod
12-28-2003 16:35:38
wd 40 evaporates I would use good motor oil or just leave it alone if under cover or inside unlikely to stick.
regards
rod
CH
12-28-2003 16:45:01
 Re: Re: Need a Quick response in reply to rod, 12-28-2003 16:35:38
Thanks Rod,
Gonna take the truck out and shine the lights on to do this then tarp it. No more room in the barn and tarps tend to hold in moisture.
Indydirtfarmer
12-28-2003 16:42:00
WD-40 is actually a solvent. It will wash away any oil that was left on the cylinder walls, doing more harm than good. I would try a good motor oil, and let it go at that. JMHO. John
scotc
12-29-2003 19:54:01
 Re: Re: Re: Need a Quick response in reply to Indydirtfarmer, 12-28-2003 16:42:00
use whatever you put in the crankcase, wd-40 will encourage things to rust
