Tractor Talk Discussion Forum
International 806 that will not turn.
Nathan Bolzeniu
12-29-2003 05:45:58
I own an International 806 that won't turn. The tractor is a wide front with power steering. I removed the pump and cleaned and inspected it throughly. I drained all the fluids and replaced them with Case International brand fluid,and it still will not turn. If you know any thing that may help me please respond. Thank You
Joe carr
12-29-2003 19:56:11
 Re: International 806 that will not turn. in reply to Nathan Bolzenius, 12-29-2003 05:45:58
Try bleeding the air out of the steering lines.
scotc
12-29-2003 19:49:47
we blew a steering line on our 2+2 and ended up replacing the hand(?) pump (under the dash attached to the wheel), steering wheel would not turn. if the wheel turns i'd guess mcv
p-c-y
12-29-2003 16:22:16
could b the front pump.
flow dividrer
valve stuck in multi control body
Rob
12-29-2003 07:45:58
My father had an oliver that had similar symptoms. His was due to a broken casting where the tie rods were attached to the steering motor under the front of the tractor. It might be the same sort of thing. Good luck.
Larry806
12-29-2003 07:10:42
We had a 1206 that set for years that did that All that was wrong was the front axel was sezed I jacked the front up & greased it while having some one turn the wheels One side had to be heated to break loose
