Tractor Talk Discussion Forum
bobcat 722
jb
12-29-2003 13:50:30
does anybody have info on the drive system on this the right sticks and you have to goggle the lever to get it to go after that its ok then when it gets hot its sluggish to operate thanks JB
Jailkeeper
12-29-2003 19:59:57
 Re: bobcat 722 in reply to jb, 12-29-2003 13:50:30
Check all the linkage pivot points for worn or binding parts. Also, I had a few 753's that had broken springs on the top of the hydrostat unit. Where the linkage hooks on the hydro, there should be a centering spring. If these are bad they can cause problems like you descibe, but usually the machine will want to move and "drift" on it's own.
Have to be real careful messing around with the hydro linkages. It is very adviseable to have the machine up on blocks so the wheels are off the ground when doing any work on the hydro or linkages. Saves getting ran over or replacing shop doors/walls.
