Tractor Talk Discussion Forum
Massey Harris 44
Doug
12-30-2003 11:15:01
My Massey carb and manifold freeze up in the winter after the engine warms up. What is the resolution?
DaveInMI
12-31-2003 05:00:35
 Re: Massey Harris 44 in reply to Doug, 12-30-2003 11:15:01
Side curtains or heater hauser should work. I made my own and it solved the carb ice problem.
Gary-Miss
01-01-2004 07:36:29
 Re: Re: Massey Harris 44 in reply to DaveInMI, 12-31-2003 05:00:35
Use some de-icer in the gas. You will still get the frost on the outside of that long intake, but, you won't get the ice on the inside
Farmered
12-31-2003 04:45:02
Doug, That 44 has a long neck on the manifold that is prone to frosting up. I agree with the other posters that addition of a gas additive such as Drygas or Heet will help. It is not only for preventing gas line freeze ups. Also the gas with 10% ethanol will help if it is available in your area. The gasoline evaporating in the venturi acts as a refrigerant and will cause icing even at ambient temperatures above 32F, especially if the relative humidity is high. Ed
Scott Green
12-30-2003 16:48:23
put in some gasline anti-freeze(isopropal) , and forget you ever had iceing up problems. That's what we have done for years. Just so happens , one of the tractors we had run in the winter was a Massey Harris 44.
rustyfarmall
12-30-2003 13:20:14
You can fabricate a sort of oven out of a large coffee can or similar item. Simply cut the bottom out of the can, then split the can down one side, and form it around the carb and intake. You may need to notch the can in a few places to clear some obstructions. Once you get it to fit properly, tie it in place with some light duty wire. It's not a cure-all by any means, but it will help.
Doug
12-31-2003 06:27:50
 Re: Re: Massey Harris 44 in reply to rustyfarmall, 12-30-2003 13:20:14
Thanks folks for your suggestions. I now get the drift. Does anyone know if the freezing up would cause the carburator to flood?
Dan
12-30-2003 12:08:21
An Oldtimer told me once to let it run until the engine warms up,then shut it off until the frost melts off, then run it again,should be good, not much else you can do with those updrafts.
mh33
01-03-2004 09:43:40
 Re: Re: Massey Harris 44 in reply to Dan, 12-30-2003 12:08:21
i have the same problem on my Massey Harris 44.
The intake gets frost on the outside of it.
Will the frost hurt anything?
