Tractor Talk Discussion Forum
Radiator flush???????????
Jerry Bliler
12-30-2003 21:33:36
Am looking for input on what folks use for flushing radiators and heater cores. Have a slow flow through the heater system and am told it needs a good cleaning. Is thte Prestone super flush the best to use or is there better stuff to use?
Mark in AB
12-31-2003 07:50:27
 Re: Radiator flush??????????? in reply to Jerry Bliler, 12-30-2003 21:33:36
Any of the standard cleaners work great, just get the system hot and make sure to leave it in long enough, best is to flush out the system with plain water, then refill with water and the cleaner and work the tractor for a day. you will be amazed at what comes outta the drain plug.
Randy
01-01-2004 08:35:33
 Re: Re: Radiator flush??????????? in reply to Mark in AB, 12-31-2003 07:50:27
You could also fill it with vinegar and let it soak in. I hear it works good and is cheap.
