Tractor Talk Discussion Forum
4240 Will not start with key
Justin Lewis
12-31-2003 16:55:01
I have a John Deere 4240 yhat will not start with the key. I have to jump across the starter with a screw driver. I have not been able to find an manual with the complete electrical system. Any help will be greatly appreciated.
Thanks
Justin
Justin
01-03-2004 13:30:50
 Re: 4240 Will not start with key in reply to Justin Lewis, 12-31-2003 16:55:01
O.K. guys today i tried what you suggested. First i tried the saftey switch no change. Then I tried jumping across the terminals on the solenid under the hood and it would spin over. But when hit the key it would just click. So i went to Napa and bought one just to try and it wound not even click. Nothing. So i put the old one back on and back at the same point. It justs clicks. I do not have an maunal for it. So i need all the help you guys can give me.
Thanks
Justin
buickanddeere
01-01-2004 19:52:04
Ever wonder what a farmer, the tractor and the shed look like after a tinker screwdriver start? The tinker pleased with hearing the tractor roar to life now has about 1/2 second before the pumps build pressure, engage the clutch packs and the tractor leaps forward. Not pretty with the tire or duals and the equipment behind driving over the tinker. And no matter how fast you are you can't see,react and leap clear in time. Nasty mess for the family to find and the emergency service workers to clean up.
PawPaw
01-01-2004 17:25:09
I had a Ford once and worked on it all day. Finally found out the PTO was engaged.
Mike w J
01-01-2004 07:54:10
the neutral safty switch has shim washers on it that can be removed after they wear a little they don't always make contact but that relay could also be bad to test the neutral switch unhook the plug and put a jumper wire between the 2 wires THIS IS ONLY A TEST AND MUST NOT BE LEFT THIS WAY
Van
01-01-2004 20:33:36
 Re: Re: 4240 Will not start with key in reply to Mike w J, 01-01-2004 07:54:10
Why not just check the switch with a meter? Does anyone know how to use a meter anymore to check switches? Screw driver starts and bypassed switches lead to dead or mangled farmers and sad families.
twopop
12-31-2003 17:55:05
under the hood,on the left side of the firewall,there may be a solenoid that energizes the starter.I say may be because I dont remember when deere changed to a relay.yes,check the nuetral safety switch also.is this a quad range?and are you sure its in nuetral.
Justin
01-01-2004 06:37:46
 Re: Re: 4240 Will not start with key in reply to twopop, 12-31-2003 17:55:05
Yes it is a Quad Range. It has the A,B,C,D ranges.
I will check the switch by the shifter arms and the soleniod under the hood. I know it is there but when i turn the key it just clicks.
Justin
Mike (WA)
01-01-2004 08:06:50
 Re: Re: Re: 4240 Will not start with key in reply to Justin, 01-01-2004 06:37:46
If it clicks when you turn the key to "start", its probably not the neutral safety switch, but rather, the solenoid (which you are now bypassing by jumping with the screwdriver).
Bob
01-01-2004 08:27:55
 Re: Re: Re: Re: 4240 Will not start with key in reply to Mike (WA), 01-01-2004 08:06:50
Justin,
When you turn the key to"start", which solenoid clicks... the one up under the hood, or the one attached to the starter?
Justin
01-01-2004 12:47:20
 Re: Re: Re: Re: Re: 4240 Will not start with key in reply to Bob, 01-01-2004 08:27:55
The soleniod under the hood is the one that clicks.
Bob
01-01-2004 14:13:49
 Re: Re: Re: Re: Re: Re: 4240 Will not start with k in reply to Justin, 01-01-2004 12:47:20
Justin,
Have you tried (having made SURE the tractor is in neutral), to jump across the 2 large terminals on that underhood solenoid to see if the starter will work that way? Sounds like the under-hood solenoid is bad.
Bob
12-31-2003 17:13:11
Check the neutral start switch. If it is not a power shift, the neutral start switch is a hex-headed unit screwed into the side of the transmission case near the arms the shift rods connect to, with a 2-wire connector on it. Power shift may be similar?
For goodeness sakes, be carefull when troubleshooting it, and get it fixed before you run over yourself!!!
