Tractor Talk Discussion Forum
tractor stops when it gets hot
abane
01-02-2004 09:11:50
I have a Farmall A that I cultivate with and it starts good and runs good for about an hour and it stops running and will not start again until it cools off and will do the same thing again.It has been converted over to a 12 volt system.Any comments or suggestions.
Polish Mike
01-02-2004 09:20:01
 Re: tractor stops when it gets hot in reply to abane, 01-02-2004 09:11:50
What you are describing sounds like a bad coil.
RAB
01-02-2004 14:46:30
 Re: Re: tractor stops when it gets hot in reply to Polish Mike, 01-02-2004 09:20:01
Or maybe a blocked fuel tank vent.
First need to know whether it is a fuel or ignition problem - not too difficult to check, then go from there. Probably is the coil or condensor - but just guessing is not the best way of diagnosing a fault.
Regards, RAB
Farmall Don
01-02-2004 11:46:48
I second that.
