Tractor Talk Discussion Forum
444 international quality
Dan McClure
01-05-2004 12:47:14
I was thinking of buying a 444 but need to know how good of tractor and availability of parts?
jimbeck1st
01-10-2004 12:34:01
 Re: 444 international quality in reply to Dan McClure, 01-05-2004 12:47:14
I have owned a 444 Diesel for 15 years and they are tuff little tractors. Mine is a British version so holding true to its heritage, it leaked a little fluid from a rear axle and I have had a few electrical problems. I replaced the axle seal and replaced the generator with the least expensive (approx $30) alternator (with a built in regulator) I could find. Excellent engine and good hydraulics. I highly recommend the tractor for light to medium utility work and you would need front weights to handle 1200 pound round bales of hay. Good luck.
Van
01-06-2004 10:42:15
I have a 354 british with the Lucas electrics, they are the only drawback to this machine. If they go bad big bucks. My starter solaniod went south, priced at$68.00 from a dealer, put a ford one back on for 6.95. Starters are very spendy also.
Ben in KY
01-06-2004 05:56:42
I have a US 444 and am well pleased with it. There are american and British versions. The British ones have Lucas electronics and the SN begins with a B. Most parts are still available thru Case/IH.
geok
01-05-2004 14:04:00
Some parts for gas engine are little hard to come by but other than that they are a good little tractor. Parts from the bellhousing back are also available from a Mahindra dealer.
