Tractor Talk Discussion Forum
Spot Putty Question (tractor tin) ???
Alberta Mike
01-08-2004 06:43:45
Finishing up some body work on tractor tin and I have a question. I started with bare metal and have used regular body filler (Bondo) and have shaved and sanded that down. Next step is the spot putty for small imperfections, scratches and edge-feathering, etc. Should I put a coat of primer on the bare metal/body filler before using the spot putty? Or should I just used it as things are now (body filler and bare metal)?
derf
01-08-2004 12:26:28
 Re: Spot Putty Question (tractor tin) ??? in reply to Alberta Mike, 01-08-2004 06:43:45
I have a 1939 general in ontario,appears to have a small 2-speed behind engine. was it optional
Alberta Mike
01-08-2004 17:19:19
 Re: Re: Spot Putty Question (tractor tin) ??? in reply to derf, 01-08-2004 12:26:28
That would be a Cletrac General GG you're talking about right? Never heard of that feature, someone must've stuck a 2 speed gear reducer in there between the clutch output shaft and the regular tranny.
Unimog
01-08-2004 08:01:56
Bondo type fillers should go on bare metal. The
spot putty usually can go over primer or on the bare metal. Most spot putty is basically thick
primer so either way is OK.
jimbo
01-08-2004 07:46:02
Use body putty on bare metal.
Rusty Jones
01-11-2004 18:10:50
 Re: Re: Spot Putty Question (tractor tin) ??? in reply to jimbo, 01-08-2004 07:46:02
NOTE: FROM AN OLDER AUTO BODY MAN---PLASTIC FILLER--SAND IT DOWN TO SHAPE, PRIME 3 COATS, ALLOW TO DRY THRU, SCUFF LIGHTLY WITH SCUFF PAD, APPLY SPOT PUTTY, ALLOW TO DRY, BLOCK SAND WHERE APPLICABLE, REPRIME, SAND SMOOTH, BLOW OUT CRACKS WITH HIGH PRESSURE AIR, WASH JOB WITH "PRE-KLEANO", A WASH TO REMOVE WAX, GREASE, FINGER AND HAND OILS, ALLOW TO DRY, APPLY COLOR COATS! RJ
